shelbysam said:
I just hooked up my used st croix hastings corn stove. i push the on button the fan kicks on for 30 seconds or so and then shuts off and a lower speed fan continues run and every so often it augers corn in, mean while the number 2 light flashes. according to the manual i believe it went into "safety shutdown" any help would be greatful. thanks
Here's the web site manual.
http://www.eventempinc.com/stcroix/downloads/dig2/Hastings_Operation_Manual_6-08.pdf
Here's the portion, of the manual, associated with #2 LED (VACUMN SWITCH):
The Vacuum Switch - For the stove to operate, the Firebox needs to be sealed.
During the first 30 seconds after the stove has been turned on the Control Board will check
if the switch senses negative pressure (Vacuum) in the Firebox of the stove. If there
is no negative pressure, the stove will shut down and the #2 LED will start blinking.
Vacuum switch also called the Negative pressure switch. When the stove is turned on
the Exhaust fan will create a negative pressure in the firebox. The control board continually
checks to see if Negative Pressure (vacuum) is present during operation of the Stove. If the
exhaust venting system becomes clogged or obstructed, the firebox door or ash pan door are
left open or the exhaust fan quits working the control board will go into “Safety shutdown”.
There is a 60 second window to allow for cleaning the glass and removing the clinker
before then Stove shuts down. This is sufficient for the Daily Maintenance.
**On my St. Croix, it craps out if the door is open more than 30 seconds.
Once that happens, I have to wait for complete shutdown(no fans blowing) before I can restart.
Use the dollar bill test and check the door the gaskets for leaks.
I also read where the Hastings can be used with a maximum 50% corn and 50% pellets.
