I am also considering a stack robber (a blower that goes in the chimney stack right above the stove). Someone told me that they are dangerous as they sometimes burn through. Thoughts and comments will be appreciated.
They cool the flue gases down quite a bit and usually are not worth the risk or hassle. What type of stove do you have and what is the flue setup? But with an old inefficient stove that's sending a lot of heat of the flue, it might recover a bit. Expect creosote accumulation to go up proportionately.
We are getting a new efficient stove (either blaze king, harman tl300 or pacific energy (that is in another post). We can also get the chimney and stacked worked on so I was just wondering if the stack robbers were worth it.
Definitely not recommended on a modern stove, you've already paid for the efficiency by getting the new stove. This is particularly true for the Blaze King. The flue gases will already be quite cool coming from the stove. Robbing the stack is not a good plan. I like to put double-wall pipe on an EPA stove to insure the flue gases stay warm enough to discourage creosote condensation.
I also forgot to mention, these things are noisy and ugly.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
