slls
Don2222 said:slls said:rona said:I just leave the thermostat on 70 and add fuel as needed. It can be -20 here with no wind and the stove will burn less then if it was +20 with the wind howling.
Same here.
Can you guys with the thermostat explain PLEASE?
If it is on Hi-Lo then what is the high setting? If On-Off then what is the Heat or Feed Rate setting??
My stat is set at 70, stove is set to medium heat, high fan, has low fan also. Have 3 heat settings , high, med, low. My runs most efficient on med, I think.
No matter how cold it shuts down and waits for heat call, like my hot air furnace, works exactly the same.
