certified106 said:raybonz said:Chris I wonder if you're giving your cat too much air. If you have the stove air cut way down for a long burn you need to either keep the cat air closed or open maybe 1 turn.. At least that's how it is on this stove.. You may have had the secondary air set maybe a bit too low too.. You'll have to experiment to see what works for you.. If you have a big bed of coals the cat will turn off as there is little to burn at that stage... BTW the last post was filled up so I continued it here.. I saw what the dutchwest XL added and I am sure he can go quite a bit longer as that is a BIG stove.. Too bad it would overheat this house or I would own that one instead.. BTW Cert what vintage is your XL dutchwest?
Ray
Ray, the XL I'm using now is from 1991-1992 (my dad can't remember which year he bought it) I had a 2005 dutchwest lg in my house for a while and loved the fact the front glass stayed clean. However on really cold days I wanted 10 hour burn times (with good heat output) between loads so I traded my dad the large for his XL that was in his shop. Now he is talking about replacing the 1987 large he has had in his house with this one due to the fact he likes the clean glass and putting his old large out in the shop.
I run my secondary air to the cat at about 1.5 to 2 turns on long burns so one turn on the large would seem about right to me. However your chimney/draw will greatly effect how your stove burns and once you find the sweet spot on the secondary air it shouldn't require much adjusting in my experience.
I fully agree Cert.. Experience is everything in just about any stove and they all vary due to draft, wood quality, and user experience.. With my new insulated liner I had to adjust for the better draft and quicker heat up time..
Ray
