When I put the Fuel type on Sunflower, the fan blows high all the time. This is why Im not sure if I have software issues as well, or this is a control board issue. In this scenario and the one of low flame height, something is either inconsistently conveying the information or something is receiving it incorrectly. Im thinking of replacing the snap disc because it was popped out and machine didnt shut down. Clearly that is an issue.Leave it open. Like I said this is where the stove gets air that goes thru pot.There should be a gasket around the opening for the ash drawer. I would not worry about too much air going thru it. If you want to, you can go from high altitude, to normal. That slows down fan. And explain more on how the conv. fan runs on high all the time?
I did turn the flame heigh to +4 and the output to ML or M with better results. The room has been around 68-70 since then. It is 71 now and 35 degrees outside. Is it ok to run this thing 24 hours a day?
