I have an Envirofire EF3 at my house. I don't know its exact age, but I know its over 10 years old. It was running OK until last week when the dial-a-fire went. I replaced the dial-a-fire and the auger is functional again. The problem now, is that the fire won't stay lit. Sometimes, it will run for 4 or so hours. Other times it will sputter out after 40 minutes. The auger is running normally, but the feed is inconsistent. On its highest setting, it will feed a bunch of pellets every time the auger light turns on, but then it will go for as long as a minute without feeding any. The fire dies down during this time and then when pellets start dropping again, it buries the embers. Looking up the feed tube, the little turnstile seems to be moving normally. It will crush a pellet between itself and the wall of the tube every now and then, and this is when it doesn't drop pellets for a short time. I am going to take the auger motor out this afternoon, but I am wondering if there is anything else I should be looking for besides a jam.
I was reading one of HearthTools posts and I am wondering if I may be having problems with the seal as well. The damper slider doesn't seem to have any immediate effect on how the fire burns. What else should I check out while I have things apart? Thanks in advance.
