MD, Ahhhh..
! a cat stove!! I switched from a pre-EPA cast stove that kicked heat in a snap of a finger to a cat - soapstone stove. The switch was almost as extreme a change as you could make. But I have to tell you, I love a cat stove. My house used to range from 60 to 78. With this stove it ranges from 67 to 74. I could get 78 if I wanted it but I don't and it would stay ther for hours. Ugh!! Loaded it at 8AM this morning, the house was 72. Came home at 7PM, the house was 68. Stirred the coals a bit, threw in a bit of kindling and some junk pine, punky red maple and some white pine, and 2 hours later it's a gentle 70. It's 40 out tonight, not too cold, I'll put a moderate sized load of medium BTU wood in, put it down low and tomorrow AM it will be 69 perhaps, decent bed of coals for the AM load. The stove you have is an awesome little stove for 24/7 burning, not really at its best for on again off again use, it'll work that way but not shine. As others have mentioned, you're heating the mass of your home and once you get it there, a cat stove will do a great job of keeping it there. I think that's really key. Yeah, also, the ceiling fan is a MUST, get the heat back down where you are or put your living space up there. Yes, you're wife needs to learn all about it too. My wife is not a technical person, but after some resistance to learning about it up front she's come around, runs the stove well, and says it's the easiest stove she's ever used, and she's used a few. And you need to get past your initial concerns about firing it up a bit. I was reading the Intrepid manual and it says if you get the stove top up to 750, it's time to cut back the air a bit! Your cat fires off at around 450 stove top and you really want your cat to fire off. If you need more heat faster, give it more air, 600 stove top is fine, no problem for the stove, 700 is okay, you can run it at that all day long if you want, by 750, time to cut back a bit. But I think you will find in the long run that you'll fill your stove full, crank it up to 550-650, engage the cat, settle the air back a bit and just let that baby cruise..and cruise and cruise. You want a steady 72 degrees, you'll learn the setting that holds it there, 74?, 68? same thing. Read and re-read your manual. Play with it and try different things. Once you understand how the cat works and learn your stove in your house in the different weather conditions, I think you'll find a cat stove is one of the easiest to live with. After using that stove for a few months, I don't think you'll be selling it. Enjoy!! Lucky guy, a cat stove!!
