Is there a nut inside the top area of the stove to adjust the bypass door tension? Since my stove is cold for a few days I checked the gaskets. Door gasket is tight with the dollar bill test but it pulls out on the bypass gasket.
I know this wasn't a recent comment, but I had to reply.And don't be afraid of softwood. The BK was made in the PNW where softwood dominates. You won't get quite as long of burns but even the carppiest cottonwood in a BK will burn longer than the best hardwood in a non-cat, well probably, we don't have much ironwood to try.
I have burned lots of Aspen in my king and now my princess. Very similar to cottonwood for burn times. To me Aspen is an easier wood to process, no bark and generally very straight with small limbs. My son did a science fair project burning measured amounts of wood of 4 local species of fire wood. Aspen put out the most heat the fastest, but also burned out the fastest. Douglas Fir just beat out lodge pole for high temp and longest burn. The Russian olive was mid pack.Does anyone who burs Cotton wood have access to Poplar? I was just wondering I have an abundance of Big tooth Aspen on my land , we just call it Poplar up here. I am wondering how Cotton wood compares to Poplar for the heck of it.
I will be opening up a sugar bush on a small portion of my property this winter. While in there marking trees for removal and some very large Poplar are in there as well .I was told by the forester to just drop em and let em rot if I had no use for them but get some of them out of there to open up the canopy some. Most are between 70' & 100' tall I would guess about 2' to 2.5' on the stump. I had planned on hauling the good tree length out to my normal wood yard and make another yard for the much less desirable wood in another yard. Some fir and Pine and of course Poplar. Maybe I will work up a tree and burn it next fall , I bet there is 1/2 a cord in some of them alone.
for veneer. In my area I would haul them to the lumber mill and put a few extra dollars in my pocket rather than leaving them to rot.You are correct. Tulip is the tree that's most commonly called poplar.I think what I've always thought of as Poplar is really a Tulip tree or Tulip Poplar.
Correct, after all it is deciduous.Also note it is classified as a hardwood but it dryes, lights, and burns like soft wood.
Not so with the black cottonwood here in the PNW. Straight as a string except around knots. Gotta split it when it's soaking wet though, it just pops apart. When it dries, however, it's so soft it just absorbs the maul and is a bit more stringy too.Cottonwood is great to burn but let someone else split it for you... The grain in those trees is so twisted
Sent from my SGH-I337M using Tapatalk
Not sure what my deal is, but I still have a deal. I ordered a brand new t stat for $220. I have it adjusted when cold to 7/8 open, as that's what bkvp told me. It's just not working right. It will never close all the way. Like, it's still a quarter of an inch open when the cat guage is pegged. Burning up my load of wood super quick, and super glowing cat, needle pegged, and can't shut the damned thing down. Almost scary. Pretty sure everyone else with the normal stove with the totally different t stat can close it down while it's cold. So, I moved it down a little more than half an inch open when cold for the next fire. There's oval shaped holes in the t stat when you mount it with two screws, and gives you the ability to move it up or down a bit. It's just like there's no enough play in the spring. It will not close when hot.
Now on my next fire, it went out with wood still in it. The problem is it's not smart, or hooked up to the cat guage to know when it's going out or running too hot. It simply works off the warmth of the stove. Would be nice to have a smart one that worked like that. So then the fire goes out, or almost out, cat goes inactive, and then it starts to open up a tiny bit, making the wood smoke again which just smokes the hell out of the new cat, and new liner for an undetermined amount of hours. NOT what I want happening. It wont get hot enough to re fire the cat up. Not sure what to do from here. Maybe I still have a small leak from the bypass, maybe it's too warm outside. I don't know. It's just a pain to have to be here to babysit this thing, and make sure it's not over firing, or dying out when I turn the fan on. The fan even at half way really brings the cat temp down. You'd think the t stat could compensate and open up when the cat is about to go inactive. It doesn't though. It's like I'd be better off just making the thing like a normal stove without springs n stuff, and just set the damn thing and walk away like most stoves. I don't even care about extra burn times at this point, I just want it to burn at a constant rate, and until all the wood is gone, and then go inactive so it can't ruin a brand new liner.
