If you burn a few sticks a couple times a year for "ambiance", the original cat will probably outlast the stove.  If you use it for primary heat in a northern state, you might hit 12k hours in 2 years.
My first Jotul still had the original cat in it after 20 years, when I purchased it.  It worked just fine, I don't think the prior owners ever used it much.
			It was always my belief that compressed air, even at low pressures, would -ike a high pressure washer stripping paint from wood-strip off the flaky very soft invisible catalytic coating.
Maybe, but you can't really get a vacuum with any brush attachment I've ever owned onto that cat, and even doing my best with the vacuum it was still clogged.  A paint brush... not going to help suck debris out of steelcat passages.  In the end, I don't really care if I took off a little substrate.  I have to do this every few weeks, on this stove and it always goes from "not working" to "working fine".  When that ends (and I already have more than 10k hours on it), then I'll get a new one, and repeat.
I believe you have read that you shouldn't use compressed air, I've read the same.  I also believe that such instructions are written to protect the manufacturer, more than with any thought to a user's real situation, or ability to execute an operation without damage.
			They make them for double wall. If available that's the way I would go. What brand stove pipe?
Not sure of brand, purchased from Rockford.  Just checked email receipt (2015), and it reads:
Item: Double Wall Black Stove Pipe
Quantity: 1
Description: Stove Pipe
Size: 6 in. dia. x 24 in. length ADB6 5.8 C - 89.99
Price (each): 89.99
Item Total: 89.99
			186$ free shipping for an oem replacement.
You Princess guys suck!  I believe the 30 box combustors are much more.
			Are you having a smoke smell issue also?
No, I've never said that.  With all this talk of smoke smells, I have actually spent time putting my nose oils all over both stoves.  If I get right up on the one with the taller chimney, I can actually smell a creo smell on the top hinge side corner of my door, but I can't smell it at any distance from the stove.  Highbeam's "dog's butthole" theory.  I occasionally get a smoke smell in the house, maybe once per month, but the few times I've bothered chasing it down I find it's coming in from outside.  My house has a U-shaped floor plan, with a stove at the end of each leg of the "U", and some wind conditions carry smoke from one chimney across the other side of the house where it can be drawn in thru leaky windows and doors as make-up air.
However, for full disclosure, my house was BUILT for burning wood.  The original owners appear to have had five or six stoves in this house, and we have sufficient make-up air thru these mid-18th century windows and doors, that even the occasional reload smoke will dissipate in reasonable time.
			In my opinion there should be a “wiki” of sorts for the BK stoves rather than a massive thread... I check in on it occasionally and find smoke smell, dial settings, cat cleaning, and other similar repeated questions. Well the smoke smell thing needs it’s own thread (for the record my sirocco has been clean as a whistle, not a hint of smell and I do hope that issue can be sorted for the unlucky few who have it.)
You just need to check in more often.  These threads are a great way to stay on top of all things BK, so much so that the half dozen spin-off threads that are floating around out there (mostly on the smoke smell issue) sometimes feel like rogue states.  The forum is fully searchable, and you can display search results by post, not just thread.
			View attachment 220852 Got her up and running after a bit of a rough day installing the chimney liner.  One thing I did notice is the fan stays the same (noise and blower air) or seems like it does no matter what setting I put it on.  Does this sound right or might I have a faulty switch?
One of my blower kits had the rheostat not adjusted correctly, and also had a very small range of operation.  If you remove the knob, you'll find a small adjustment screw on the rheostat, which you can turn to set the low point (just barely spinning on lowest knob spinning) to get maximum range.  Note that a screwdriver between this screw and the blower housing will short out and blow up the rheostat (DAMHIKT), so you may want to use a plastic screwdriver if doing it live.
