What Diabel said. No ash door assistance. If need be crack the front door until you get some flame. Definitely get a moisture meter. It’s fine to put a few small splits on top of the coals for easy light off but top those with bigger splits.
If your fire goes out shortly after, it is a wood issue, not a draft issue most likely.Hey all,
As of last November I have been the proud owner of a brand new Defiant 2in1 model 1975. It's vented straight up into 8" pipe, a 6' single wall section followed up by about 13' of double wallrigid pipe sections. I have previously owned an older vigilant and have been woodburning for about 30yrs
This is one very finicky stove, and most I can say is that it is starved for air. The unit is very tight, once I get a good fire burning by letting in extra air through either cracking the front doors or cracking open the ashpan tray (just a hair cracked will do the trick)
As soon as I close it up with the primary air fully open the flames will almost immediatly cease and the stove will just die down leaving some of the wood unburnt
If I give it some extra air I can control it better and it will burn down completely, if feels like something isn't right with this stove and I am considering adding another adjustable air intake into the ashpan door to gove it a bit more air, obviously I don't want to leave it unattnded with the risk of the ashpan door falling open or the same thing happening with the doors.
I will still have to move this beast to install the vent kit and hook it up to outside air and I'll take a good look at the primary air intake on the back.
Sent from my iPad using Tapatalk
I understand the ash door assistance issue. I found this by accident the first day of use when the latch wasn't secured all the way and I couldn't get the fire to calm down. Was amazed at the draft it created through the fire with the damper open. Basically making it run like a coal stove. Still learning a lot here with this stove. Lots of physics in play here. Maybe not science as the manual says, but definitely physics. I never thought it was possible for wood to be too dry. But it is apparently now days. Which begs another question. What do you do with wood that's too dry? Moisten it up somehow? Discard it? Kevin
is it controllable after the cat has been engaged?I've been burning pretty dry wood, wood that's seasoned for 3+ years in my wood shed, as I read up on it and that this stove doesn't take green wood very well.
I still feel there is something not right with the amount of air it lets into the stove. My Vigilant (although a European model) was fool proof and would be very controllable with the primary air intake, on this stove i basically see no difference in any primary air setting
These newer epa stoves are a different beast than your old stove. You are singing the same song a lot guys do when they upgrade from their old stove. Can we assume your chimney and cap are clean and not plugged up?Hey all,
Getting back to the Encore back puffing. Still doing this with what I think is right okay draft. It's always when the fire is at a certain level of solid wood left to burn and is off gassing. The fire seems to start smoldering erupts into flames underneath the griddle with smoke puffing out around the griddle, nowhere else. Thought the least resistance to this would be out through the combuster, no? When I add bigger pieces or pieces with a higher MC it does not happen. Does size really matter that much or is it MC. The manual alludes too dry wood could cause this no matter the draft. Boy that would make this a very finicky stove too operate. I haven't heard anyone really say this but it appears the engineering on this is that no matter the draft, for the catalyst to work you can't have too little or too much draft going back through it, yes, no? Just trying to get it figured out. Other than this issue the stove I think is running well. Right now I have only at best 4" pieces mostly about 3 to 3 1/2 thick. I had a small Waterford Leprechaun stove before so that's the only wood that's seasoned I can use right now. Next year will be different. Got that CSS already. Any thoughts or comments appreciated. Will be changing the one 90 stove pipe to two 45's and eliminating near a foot of f horizontal so that should help. Kevin
. I'm still going to replace the 90 in the stove pipe with two 45's so this combined with what's been said above should be the total cure. Thanks all. KevinIf you can get her to give up the top loader the blaze king Ashford 30 gets a lot more love around here and has top notch manufacturer support as well. It’s hard to beat the looks of a VC though. I think there are a few flexburners on here hopefully the chim in for you.Maybe now I'll get it right.....here's the question, and your reviews on the Vermont Castings Flexburn 2in1.
The wife wants/needs the following for a new stove which is why the VC Flexburn looks like the only choice :
Top loading
Pretty
Enamel (not brown, not red, not white )
Catalyst ( friends have Woodstocks )
I said "pretty" ?
Thermostatic air control.
Me ? Reading here about the problems with Vermont Castings is a problem for me. Have they changed in quality ? Service ?
Any using the Flexburns 2in1 for a season of heat or more have concerns ? Reliable ? Warranty issues ?
I'm going on 3 years with my 2n1 encore. I feel like with the exception of the cat breaking, the issues have been wood related. I have contacted vc direct and they were very helpful. They do like you to do everything though your local distributor, so if you don't have one, that might be a problem. Start getting your wood dry now, the 2n1 is sensitive. You can always burn it hotter, and clean more often.Maybe now I'll get it right.....here's the question, and your reviews on the Vermont Castings Flexburn 2in1.
Top loading
Pretty
I said "pretty" ?
Top load is my favorite. I only open the doors to clean and for a cold startYup, I wanted the Ashford...but she said no to the looks, to the front load, to the enamel colors.. I must obey so far.
And why is BK the only maker who posts here ? Impressive. No Woodstock, Jotul, PE.
Same here. Top load is very convenient.Top load is my favorite. I only open the doors to clean and for a cold start
since I was not comfortable with Vermont Castings' rep.We use essential cookies to make this site work, and optional cookies to enhance your experience.
