Looks like red oak.Are those railroad ties?![]()
I feel sorry for his chainsaw if they are RR tiesAre those railroad ties?![]()
Whatever you throw at the BK.....it will burn.I feel sorry for his chainsaw if they are RR ties
Please post a picture of your full load.Just a quick follow up, after a couple of loads I’m still learning, but my burn times are getting better, pic below is what was left at 12hrs yesterday, cat just below active. Was up on the cat and shut down within 10-15min after a reload of mixed softwood. I’m still baffled at how to get a 24hr burn!! Need to modify my damper, as even with it shut all the way I still draft at .10” I will say it is heating the house nice, much more even temps between upstairs and downstairs as compared to the summit.
That's a great looking load!Close to zero tonight, I still love how these stoves can be loaded.View attachment 257031
Looks like red oak.
Nice. That's almost full.![]()
Did you add those washers on the hinge pins under the door frame? I added them to mine but they weren't on there from the factory in 2012. It helped the gasket line up with the stove front better.
Your firebox looks like mine after being stirred and about 18 hours burning on low with straight doug fir. With an ashier wood like red alder that coaling stage lasts much longer. My chimney is only 12' tall so my draft strength is surely lower.
Normally, that many coals will be enough to keep the cat meter well into the active range. When your stove is stone cold, does the cat meter point to the bottom mark of the inactive range? I'm worried that your meter might be under reporting.
Hey SS, check out this post I made earlier about a grate to cover the ash plug hole in a BK Ashford. It makes cleaning ash out of the stove without losing your coals a breeze. I just cut every second bar out of the grate using a cutoff tool, takes 30 seconds, to get a reasonable grate spacing that will allow ash to fall thru. It’s definitely worth a try, if you’re cleaning out frequently.When you burn heavily coaling wood like oak, locust or hickory- too much ash becomes an issue. The coals sink in and cool off. They are smothered. I shovel out partially about every 3-4 days with a full clean out every 2 weeks or when weatherand burn cycle allow.
I came from owning several Jotuls with a grate floor to the BK’s with their ash plug system, and I wasn’t really a fan of it at first. In fact, I’m still not. You lose too many coals down the hole, while trying to plow ash into it. But I have a solution.
I bought a 3-7/8" diameter cast iron floor drain grate (https://www.mcmaster.com/2413K1), removed every second bar from that with my die grinder, and now I just drop that into the hole when it’s time to plow ash. I’m able to rake the ash and coals across this grate, allowing the ash to fall into the pan while keeping my coals in the stove. It works brilliantly.
When done, simply use the plug lifter tool that comes with your stove to lift the hot little floor drain grate out, and set it on your hearth to cool while re-installing the plug.
If BK wants to start selling these, or supplying a similar thing with their stoves, it would go a long way toward helping the users with this chore. I’d only expect a $1 royalty for each unit sold. [emoji14]
I've had no luck googling, so I'm wondering if any of you know how many psi (roughly) comes out of a can of compressed air?
Second question - what do you think the max psi you could use to blow out the cat in place before you start doing damage? I know you're not supposed to use an air compressor, but just looking to understand the details. Thanks!
Wow! That's a lot of psi! I would have thought that that much psi would be enough to cause delamination? But, I also know that BKVP has said it's okay to use the can. Thanks for the info @HighbeamI had the same questions. 60-70 psi in a can. Also consider the size of the nozzle on that can because what we’re concerned with is velocity.
An air compressor is perfectly suitable if not superior substitute if you are smart enough (I know you are) to crank down the output pressure. I found 20 psi through a rubber vacuum hose (like 1/8”) was plenty. It also “felt” less forceful than the canned air.
Overall it’s working good, I can definitely see and feel the difference of how my summit would waste so much heat and wood those first couple hours when hit temps of 700-800. My house is warmer when I wake up in the mornings now, and I’m amazed how long the princess stays hot when other stoves would be ice cold!
Use a shop vac. Atmospheric pressure automatically limits you to 14 psi, if that were your concern.
Of course, pressure doesn’t really matter, it’s only quoted as an attempt to limit velocity.
So even with a compressor dialled down to say 10psi, there's still a chance you can damage the cat because of the velocity coming out of the nozzle?Use a shop vac. Atmospheric pressure automatically limits you to 14 psi, if that were your concern.
I think anything is possible, but I also think you’re worrying way too much about it. Cats are disposable, despite the misleading name, you use them up and throw them away after a few years. I suspect that at reduced pressure from a compressor, or with a shop vac, the only coating likely to blow off was already compromised. I just do the minimal amount of work required to get it reasonably clean, wrap it in a gasket and push it back into its hole, and get back to burning. If I took a small fraction of the coating off in the process, I’m not sweating it, as I couldn’t continue using it clogged. I’m still getting 3+ years and 18-20 cords out of the combustor, even if I am doing a small amount of damage in the process.So even with a compressor dialled down to say 10psi, there's still a chance you can damage the cat because of the velocity coming out of the nozzle?
Well said, as usual.I think anything is possible, but I also think you’re worrying way too much about it. Cats are disposable, despite the misleading name, you use them up and throw them away after a few years. I suspect that at reduced pressure from a compressor, or with a shop vac, the only coating likely to blow off was already compromised. I just do the minimal amount of work required to get it reasonably clean, wrap it in a gasket and push it back into its hole, and get back to burning. If I took a small fraction of the coating off in the process, I’m not sweating it, as I couldn’t continue using it clogged. I’m still getting 3+ years and 18-20 cords out of the combustor, even if I am doing a small amount of damage in the process.
