BKVP
Check the liner connection! Sweep effort may have broke loose the adapter/liner. That would result in decreased draft, noise etc.
I will open up the thermostat housing shortly when the stove has cooled. Hopefully can get it fixed before this cold weekend coming up.
The liner is well secured to the stove/adapter.
The disturbances were accompanied by a sudden flash of flame (wife reminds me) which then immediately went dark again.
How dry is your wood? If it's much below 15% you could be outgassing the combustor. Toss in some 18-24% and see if the same thing happens.I will open up the thermostat housing shortly when the stove has cooled. Hopefully can get it fixed before this cold weekend coming up.
No chit. well some folks will F--K up and iron ballHe got a new stove from another manufacturer and has a new thread about how that one is defective too. (Seriously.)
A piece of poplar similar to the 2 little pieces that were burning seems to be about 8-10% moisture. Just split, 62 F.
This is the first I've heard of 'outgassing the combustor'. I thought dry was good.
Meanwhile a 5/64" Allen wrench removes the set screw from the thermostat knob, which seems to be glued to the shaft. I'm afraid it will break if I keep prying on it.
The 1107 combustor is the same size as required for the newer 40.Question for BKVP,
I have a new BK KE40 (that I love), and I am wanting to buy a spare combustor just to have one on hand in case the covid thing blows up. I sent the following email to Midwest Hearth, and got the reply below. Do you know where to get a combustor at a reasonable price?
“ I am wanting to buy a Catalytic Combustor for my Blaze King. The one you have listed at catalytic-combustor-blaze-king-classic-parlor-ultra-5-x-10-6-x-2 has the following models listed as compatible.
King Classic KE1107BK
• King Parlor KE1107LBK
• King Ultra KE1107UBK, KEJ1100, KEJ1101, KEJ1102, KEI1300
However, mine is the new Blaze King KE 40.
Does this model fit in my new KE 40?”
Thank you for your email!
I do not have a combustor that is listed for use in the KE 40 stove.
If it is a newer stove, you may want to investigate Blaze King’s 6-year warranty on their combustors.
It should be in the back of your owner’s manual.
Kind regards,
Jason
So it would seem. The poplar stacked along with the oak seems to have dried much faster and further.Dry is good. But if a dry, well-charred load is dialled down too fast, it can (initially, until it has died down more, which might take half an hour or more) produce a lot of gases as "food" for the cat. If it's more than the cat can process (i.e. you're out-gassing it by supplying too much), one could get an increasing gas concentration in the box, resulting in the fireworks mentioned.
Where did the "plink" go for 3 days? Can't fix it if it ain't broke.
Already covered in another thread here:p.s. This Guardian article from 3 days ago discusses wood burning in Fairbanks and Blaze King specifically:
Natural but deadly: huge gaps in US rules for wood-stove smoke exposed
The government spent millions subsidizing new wood heaters supposed to burn more cleanly. But an investigation has discovered critical flawswww.theguardian.com
At 78 pages I didn't see any point in adding another 4 here. Link added.If that's the new rule, we're going to have one to two new threads per year from now on...
So is that sheet metal basically just a spring that wedges each edge of the cat? Or is a clip that catches a lip?
Just a spring that jams in the bottom and a short one up one side.
I originally planned to do four, one on each side, but 4 pieces of .030 sheet metal are .120" even if they are folded perfectly flat, and I was worried about thermal expansion clearances at that point. So it's just a horizontal and a vertical now.
When I retire this cat, I think I will braze the tabs to the steel case as a test run... probably have to cut the steel can open, remove the catalyst, do the brazing, and reassemble... I have a friend who has the gear to weld stainless too, so I might ask them to do it to any future cats. Brazing is no good with the cat inside the frame as you have to heat the frame up hot enough to flatten the wash coat, but I bet you could do a couple little tack welds without even cracking the can open.
What stack? All I see is panels and a massive tree
First lay it flat. Then, using a hammer and piece of bar or rod, tap lightly on top of ramp.Trying to remove bi-pass plate from Princees Ultra to replace gasket..
Can not figure out how to get it out, it’s getting stuck on a piece of metal sticking down behind CAT area..
stove I believe is a 2009 model....... Help !!
