I think mines been sloppy sense new .
I do the same as you and @Poindexter.This is what I used to do with my Princess. When you have a pile of coals raked forward you can even out the load if you stack a few splits E/W in the back then pack it full N/S on top of that. I think it may give you a little longer burn with those E/W splits tucked back in there.
 ![[Hearth.com] 2021-2022 BK everything thread [Hearth.com] 2021-2022 BK everything thread](https://www.hearth.com/talk/data/attachments/284/284330-0c063d4100f00dde1121f99c893e8938.jpg?hash=pnsHTzU1mY)
Round 3 on my connector pipe leak, and this time it’s fixed for good
Round 1 was laying the adapter onto the flue collar, making it “snug” but that cut off the air holes for the dvl.
Round 2 was raise the adapter up 2” to the holes on the flue collar, zip some screws in, which worked and allowed air into the holes at the base of the dvl, but I continued to have and noticeable or auditable air leak when running the stove on high, due to the flue collar being 6” and the inner adapter piece being 5 & 5/8” with screwing the inner piece I couldn’t get the seal needed.
Round 3 was the fix, picked up a 24g 6” single wall male to male, the male end slid perfectly and snugly into the flue collar, had to trim approx 1/2” off the end so that it wasn’t going past the flue collar opening into the cat chamber. The inner dvl piece slid perfectly into the other male end.
Loaded the stove up with smaller splits and a let a fire rip, lots of heavy flames, T stat wide open, no air noises what so ever, very, very happy.
View attachment 284302 View attachment 284303
No screws yet, it was a very tight fit to begin with and I was testing it out first (wanted to have that oh crap let me swap it back fast to its original setup time) I will be screwing it now that I know it works.So did you screw the bottom of the appliance adapter into the top of the male/male single wall? I couldn't see the screws. I think member @webby3650 has suggested a similar solution but with a more attractive chunk of single wall at the stove end.
Just for show, it was on the old stove and traveled over, it doesnt do anything other then put scratches into the stove paint, but I digress.All that aside. I still do not get why the stove top thermometer…..is that a permanent fixture?
Burn times are going to vary with the wood, draft strength, house heat loss, etc. A range of 24 on low to 8 when being pushed for heat is probably realistic.Hello friends, I’ve just ordered a BK Ashford Insert in black. I’ve been burning wood for a long time in other units. So, I know the basics; dry wood, full load cycles, clean chimney, etc.
I also know that each stove has its own little idiosyncrasies. What are some stove specific tips, tricks, hints, hacks and advice for the BK Ashford 25? I’m super excited to get this new insert and I’m really looking forward to hearing from you.
Questions I have:
What are realistic burn times on low, medium and high?
 ![[Hearth.com] 2021-2022 BK everything thread [Hearth.com] 2021-2022 BK everything thread](https://www.hearth.com/talk/data/attachments/284/284379-69b31c8ac7a2a710673ad559859ddefa.jpg?hash=ISfQ-qV0M6)
Not sure if 24h is realistic on the 25 box. Just from reading stuff here.Burn times are going to vary with the wood, draft strength, house heat loss, etc. A range of 24 on low to 8 when being pushed for heat is probably realistic.
It’s the nature of the beast when run at lower settings which is my favorite setting.Amy idea how to get the door clean? It's almost blacked out.
Did the wet newspaper and ash trick. No dice.
Ran it on high for 2 hours with a small stack and never cleared. Should I clean it hot?
Scrape it off with a razor?
Using 18 month old ash wood kept under a pole building lean to. Split the largest splits, all read around 12-14% moisture.
View attachment 284350 View attachment 284351 View attachment 284352
Looks like a nice supply of wood!Amy idea how to get the door clean? It's almost blacked out.
I really lucked out. Guy that does lawn care for a estate took on that project. Whole fence row of ash trees that got taken out by the ash borer. He filled up 12 loads on my 7x16 tandem axle trailer and didn't want any cash except 20 bucks a trailer for gas for his skid steer (so I didn't have to load them there).Looks like a nice supply of wood!
How many seasons have you had the stove? My glass cleans up pretty good when I run it on the hotter side when it gets cold. It blackens right back up when I run it on a lower setting but it’s worth it to me to keep the house from over heating and longer between reloadingI really lucked out. Guy that does lawn care for a estate took on that project. Whole fence row of ash trees that got taken out by the ash borer. He filled up 12 loads on my 7x16 tandem axle trailer and didn't want any cash except 20 bucks a trailer for gas for his skid steer (so I didn't have to load them there).
Honestly probably had 10 more trailer loads but my back gave out on me, and I told him I wasn't that greedy and he didn't need to hold it.
Now I figure if I get 2 trailer loads of free wood a year on Facebook marketplace I should be good to keep it stockpiled (already found 3 this season).
Lest fingers are pointed, this was noted by several mods. The bounds were stretched or overreached several times. It's not fun for a new person seeking information to get bombed with comments like my stove is the best, no contest. There is no such thing and it is not helpful.
Questions I have:
What size splits work best for you (length and diameter of split size)?
What is your preferred wood loading procedure (NS, EW, cribbed, etc)?
Any other hints, tricks, hacks or processes that work for you?
Thank you! I will consider this advice.I don't actually own one of those, but I have left drool spots on a Boxer 24 (same innards) at my local BK showroom.
On hot reloads I would first try scooching the live coals to the front right, then load the full depth middle section NS so you can see end grain, and then maybe put a fair sized split cut to 8" length - vertically- in the remaining open area at the left front.
It may not be worth the trouble. If you got a bunch of live coals it might make more sense to bring the coals to both front corners and then load N-S in the middle. I got nothing on burn times, too many variables. Good luck.
Thanks! I know this is not an exact science, but I’d love to hear some real world experiences of Ashford 25 owners.Burn times are going to vary with the wood, draft strength, house heat loss, etc. A range of 24 on low to 8 when being pushed for heat is probably realistic.
Not sure if I do this differently than anyone else, but I noticed that the Boxer has a storage space for wood below the firebox. I never store wood inside, there's always lots of critters in firewood (insects, mostly), and when you bring the wood inside and let it warm up, they can get very active...I don't actually own one of those, but I have left drool spots on a Boxer 24 (same innards) at my local BK showroom.
