Hmmm Ok. I misunderstood you. Seems like that stack should give you plenty of draft. Did it always run that cold? My next guess is the cat is shot.... but could also be a big secondary air leak into the cat. Weird....I completely agree. This is why I am thinking that I am having CAT issues. Other than the cat not going to temp the stove is running fine. On reload the cat will get up to 650-700 or so, but it will quickly fall down to within 50 degrees or so of STT. I have the Auber and walk by it and see the Auber at about 650 most of the time. At 700 degrees I'd think that the CAT should be lit enough to start generating its own heat and start making it's way to 1000+ degrees. Also on reloads I push all coals to the back of the stove. Even If I dont close my bypass I get a raise in CAT temp since I pushed all of coals to the back. As far as draft goes I haven't had it measured, but I have good draft. I go out the back of a stove to a T then straight up. My house is 2 floors with 10 ft ceilings and a very steep roof. The chimney is at the top of that so I figure 28-30ft once you include the attic.
I am using a perfectprime datalogger model TC0520 to collect the data. Then I export it to excel and make the plots. You can buy them on amazon, $180.
I also have 2 watlow temp controllers that I use for readouts. The data logger can handle 4 channels but it has an lcd screen that I can't read in the dark and can't see from my couch....
![[Hearth.com] 2022/23 VC Owner thread [Hearth.com] 2022/23 VC Owner thread](https://www.hearth.com/talk/data/attachments/306/306977-20e95cbca9a4efc851d8e9e7530cac6e.jpg?hash=EX9Zigq4iB)
![[Hearth.com] 2022/23 VC Owner thread [Hearth.com] 2022/23 VC Owner thread](https://www.hearth.com/talk/data/attachments/306/306979-b1abcfcc7987f9c7c7ce74c0f464cba9.jpg?hash=nN1Bb-y69Z)
