Need help on my 25 pdvc I thought the top auger motor went out so I got a new one stove started up fine then the top auger stoped working motor is good don't know what happen.
All is good do not know what happen was thinking about the one vacuum shut down switch not sureNeed help on my 25 pdvc I thought the top auger motor went out so I got a new one stove started up fine then the top auger stoped working motor is good don't know what happen.
Does anyone know the vacuum switch that's hooked to the top auger if that's a pu-vs or a cu-vs.I know they says if it stays open it will stop the top auger from runningHows the path through the stove, clean? Vacuum hose ends good, not cracked or split? Vacuum port clear? Combustion motor running good? Door gasket pass the dollar bill test? Hopper lid switch out of adjustment?
Will do I do know these vacuum switches are not factory there honeywell were replaced before I got the stove only had it 2 years.I will jump the switch tomorrow.Jump it. If the stove works correctly it's the vac switch. Just make note of where as wire goes.
Jumped switch it's works ordered new cu-vs switch seems this model take 2 different ones now I have to find a diagram from when I get new one to hook wires upJump it. If the stove works correctly it's the vac switch. Just make note of where ea wire goes.
The new switch is different it's a factory the ones on it now are honeywell guess they were replaced once before.The new.switch has the terminals kind of stacked on top of each other just got.to know if I used bottom term and top term and let the middle one not hooked up.I don't think it matters what wire goes where but matters where you have them hooked on the switchjust take a pic of yours now and put wires in the same place on new one
New switch still doing the same shuts down after 5 minutesterminals should me marked. get out the magnifing glass. or you can ck with multimeter
All that is good that's the first thing I checked and wires are on right as said from England tech support.I can't figure out why it stoped after 5 minutes of running and no error codes unless the control panel went out again but that's 2 years oldCan you post a closeup of the switch and wires? Assuming the new switch is good. And the wires are on the correct terminals. The hose is on the grey/white nipple and said hose is clear and the port it connects to in the firebox is clear. Check all the pathes through the stove and clean every nook and cranny. Then pull the combustion blower and clean in the chamber and impeller. Then check the vent and make sure it is clean and no dead critters or birds nests
Seems like flame real lazy going to try different vacuum switch and new door gasket and double check hoses I don't know what's going on with itCan you post a closeup of the switch and wires? Assuming the new switch is good. And the wires are on the correct terminals. The hose is on the grey/white nipple and said hose is clear and the port it connects to in the firebox is clear. Check all the pathes through the stove and clean every nook and cranny. Then pull the combustion blower and clean in the chamber and impeller. Then check the vent and make sure it is clean and no dead critters or birds nests
Will do now that I think about it it don't even want to light from the igniter will clean tonightOk I had this happen to me last year about this time. Going to sound far fetched but it is what it was. Check your convection blower intake screen. They get dirty with pet fur or dust along with the squirrel cage. You will need to remove it and blow it out with compressed air. When they get dirty they slow down and do not move enough air over the chamber and it trips the overheat sensor without a code being displayed. Had it happen a few times. Now it’s in my monthly cleaning schedule. My two cents but worth a try and doesn’t cost anything but about 20 minutes.
Just make sure you unplug the stove and be very careful removing the blower past the control board.Will do now that I think about it it don't even want to light from the igniter will clean tonight
My.blower is on the other side the only blower by the control panel is the one that blows the heat outJust make sure you unplug the stove and be very careful removing the blower past the control board.
Just curious where you at in Pa. That is where I am at.Will check out tonight
