2nd BK and Catalyst replacement
greg66
16
g
just bought a second BK stove, that i found used nearby.
i was looking a the cat and tought i might be good to replace it, it came with the warranty paper but it mention that it is valid only for the original buyer.
anyone know how BK handle those ?
from there i went back to check on my first stove paperwork (i am the original buyer of this one), and realize i have'nt fowarded the waranty card within 10 days as asked.
have i lost the opportunity for free replacement on both those stove?
thanks for any input on best route to go from here.
The manufacturer's stove warranty remains in place to the original purchaser. There is no warranty on the used stove. Send in your warranty documents.
BKVP
Reactions: Tron
Might as well buy a backup cat while you're at it. These are wear items. I'm on borrowed time with my current one but won't pull it until it dies comlpetely. Fresh one on the shelf.
I remember talks of steel cats years ago, and them being easier to keep in the active zone. Is this still a thing? What's everyone buying these days?
Ive run both types in my two BK's and honestly I don't see a difference in performance but I can say the steel cat does plug up faster, The steel cats are more $$$
Reactions: Highbeam
Never was a thing. Perhaps you read that steelcats become active at a slightly lower temperature? That is still true but not actually significant to matter. I have used both and defintely prefer the cheaper ceramics.
Manufacturers seem to favor steel cats because they don't physically break which reduces warranty claims.
So if they're active at a lower temperature, then they'd have to be technically easier to keep active.
But if it's insignificant and not worth the price, I'll take your work for it. So it is/was a thing, just not a significant thing.
Not really. The steel is twitchier. The fact that they are quicker to become active (at a slightly lower temperature) due to less thermal mass means that they also fall out of active range faster. There's no thermal mass to stay hot and carry the catalytic reaction as there is with ceramics. You could actually argue that the ceramics are easier to keep active.
Besides, when you run these stoves it is easy to keep either cat at active temperatures. The reaction generates heat. The only time this early on/early off issue comes up is during startup and shutdown. Some folks never let their stove shut down through the entire burn season.
Ah, so it's not a temperature threshold difference, just a transient response difference due to the thermal mass. That makes sense. The conductivity probably spreads the heat around quicker in the steel one too, but making no difference once things are averaged out.
Both catalyst substrates work just fine. Ceramic is cheaper but more likely to experience physical damage if abused. The steel costs more and plugs easier with its tiny cells. Either one works great when new, go ahead and try one of each to satisfy your curiosity.
Reactions: pvfjr
roger that chit
What are the OEM cats made from?
Princess stoves have been delivered with metal and ceramic catalysts. Seems the newest ones are using more metal cats. Mine came from BK with ceramic and my second cat was a BK steel cat, every cat since then has been ceramic because I like them better.
Reactions: pvfjr
I've run both and don't see much difference.
Reactions: pvfjr
Having burned >200 cords in >30 years in a catalytic King, definitely agree the metal cat lights off at a lower temperature (seems almost 100F lower, as advertised). Which is very important for efficiency in warmer months in my location (Anchorage) - October and April/early May.
I used my last new ceramic last year but I just replaced with my second to last steel cat a few days ago. It’s better. Steel from now on.
