Thanks folks for all the help. I REALLY appreciate it. Can someone recommend a good moisture meter? I had one I bought from harbor freight, I got mixed results with it. I would like something a little better.
Thanks again!
That I dont understand, I have a HF one and it works fine, BB like his and BK did some testing comparing it to weighing the wood and drying it in a oven and he said it was plenty good for our uses (he also did wood working) so what kind of mixed results are you talking about? Cant help think its operator error (many have reported issuses with different brands of MM).
I think BB said he compared his HF MM to his neighbors expensive one and they were basicly the same.
I thought I had lost mine so I bought another one, just not sure what people expect.
I took my HF MM and stuck it in lumber, green wood, dry wood and did the hand trick and it read fine in every case, that includes both of the ones I own.
And small splits will dry out a lot faster in the stack if you're still trying to season.re-splitting them in half has made fires 100x easier to get going
Yep. I try not to make my splits over 3-4" thick.And small splits will dry out a lot faster in the stack if you're still trying to season.
I agree with everything here. Burning wet wood is possible. It is just a damn pain in the ass. I wish to never experience it again, but if that is all you have, you can heat your home with it using an EPA stove.My first year (last year) I burned 10 month seasoned Oak mostly. It wasn't easy, but we got by without kicking on the diesel furnace once . Here is what I would recommend:
To get things going:
1) use small splits - if all you have is the oak, then you need to plan a day and get your hatchet sharpened in prep. I tried to get about two 35 gal container's worth of these small splits for kindling. Then you'll need a cord's worth of smaller splits (i.e. < 2 " dia) to put on once the kindling catches. I would also start off with some wax-based fire starter rather than newspaper.
2) leave the door cracked - sounds like you're already doing this. When I know I have wet wood, I'll leave the door cracked until I start to see the outside of the wood charred and starting to split. I'll only close the door once the temp reaches ~400 deg.
3) leave the damper open - once I close the door, I leave the damper fully open until the temp reaches 650 deg. Then I'll close it down to ~25% open.
4) add bigger logs when it's hot - I'll try to keep the running temp around 550-700 and add bigger logs on the higher side of this range. Amazing how quickly logs dry at this temp
5) burn continuously if possible - the above is a pita to do even once a day!
Obviously using this technique will consume more wood than using dry wood will, but at least you'll have heat.
-DH
That would be a great idea, but - around here - most people don't cut their wood until November I have known of and seen them out cutting wood in December and January to burn right then.
So, I guess the answer - if I stay with this stove - is to have 3 years worth of wood on hand. One - to burn (2 years seasoned), one with a year's worth of seasoning for next year, and a third just cut for 2 years out. WHICH means, I won't have a decent fire at this point for at least 2 years, because I only have enough on hand for this year. That seems just crazy. There is no buying "seasoned" wood around here. I do not know of anyone who has to deal with wood in that way. I don't have room to store 18-20 rick of wood. Well...I guess it is, what it is.
Thanks. That is probably some good advice for me. I have mixed other woods in, but I went with only oak and hickory this year ( I have a smidgeon of maple). I really like oak. But, will probably have to cut some other for next year.
Hello pastor. You are along with many wood burners. That doesn't help you today but it will in time. Just be aware that different types of wood take different amout of time to dry enough for proper burning. This for sure creates a big problem for those who do not have enough room to stack enough wood to go onto the 3 year plan but it is not so large of a problem that it can't be a deal breaker for you.
For sure one of the worse things you could do would be to go back to the older smoke dragons. Yes, they work and did for many years; we've owned several over the years. And yes, most folks never give their wood enough time to dry properly....even in the older stoves. We learned that in our youth! While we watched neighbors having chimney fires and whenever we looked at their homes we saw lots and lots of smoke. When we entered their homes and even when we got close to them, we found they stunk....bad. Fortunately I grew up in a home where we burned dry wood and not fresh cut stuff or even year old wood. For our part, we burn wood that has dried 3 years or more. By doing this, no MM is needed or wanted.
So what types of wood might you have down there that are faster drying woods? Generally you look for the softer woods that allow the moisture to escape faster than the tight woods like oak and hickory. But still some of the harder woods can work well too, like white ash. Some say it can be burned right away but do not believe it. Oh, it could be, but you would not like the results. If you have any soft maple, I know of no other wood that will dry as fast at this. Elm can be another one but be careful. Red elm may be in your area but white elm can be terrible to split and we cut it only after it has died and the bark all or mostly all off. Then it works good. Hopefully someone in your congregation should be knowledgeable but don't follow the advice of those who cut and burn in the same year!
You can also purchase some biobricks or something similar and this could help get you through the winter. Good luck.
Unfortunately, I am probably the most knowledgeable around on firewood. I am telling you - most folks cut and burn wood the same year, and never have a problem around here. They don't use much more wood than I do, and I have never heard of but one person in our area having a chimney fire in the last several years. I go in the homes of those in our congregation that have woodstoves, and I know they cut their oak that same year - their fires are beautiful, houses warm and they have no complaints. When I tell them of the problems I am having, they are in amazement. I am the only person who is having these type problems (of course I am about the only one with EPA approved stove). We have lots of maple and poplar around here, which might season in a year. I am going to make more space, I guess. I love my oak and do not want to give it up. It is the most readily available wood around here also. I will just have to make room for the 3 year plan.
You could always scrounge some demolition wood .It will be mostly pine but very dry. Anyone nearby tearing down an old house or other structure are usually happy to give away the wood. Wall studs and floor and roof joists are the best. Avoid floorboards if they are varnished and dont use painted or pressure treated wood from decks.So, I guess the answer - if I stay with this stove - is to have 3 years worth of wood on hand. Well...I guess it is, what it is.
We stack 3 rows together and stack at 4 1/2' high.
