was just curious on how catalytic combustor stoves respond to different wood? like pine, punky wood, wet wood, and wood that has not been properley seasond
fabguy01 said:was just curious on how catalytic combustor stoves respond to different wood? like pine, punky wood, wet wood, and wood that has not been properley seasond
Wet1 said:Interestingly enough, I was talking to a BK dealer in ME the other day (hell of a nice guy BTW) and he was saying he only burns green wood in his stoves, which are all cat stoves. He said he has been burning only green wood for well over 20 years in his BK stoves and has never had a problem. He probably hasn't had any problems (that he knows of anyway), but my guess is he hasn't had any problems because he turns his stoves every year (sells them as demos) before complete cat failure would have had a chance to occur.
What happens with a traditional ceramic cat is the catalyst can crack over time when the cold cat is 'shocked' with the hot steam from engaging the cat while burning green wood. Over a period of time these cracks build up and the cat will fail (fall apart) when it is repeatedly shocked with this steam. The cat manufacturers are very clear that burning green wood will drastically reduce the life of a traditional ceramic cat.
On a somewhat related note... I understand BK is now starting to beta test SS cats with their stoves. Their new stoves (King models only) being made right now are shipping with SS cats. I don't know much about SS cats, but I understand they are not nearly as prone to cracking due to thermal shock, so they could prove to be more reliable and resilient to this phenomenon. I hear the the SS cats light off a little sooner as well, but I haven't seen any data first hand to prove this is true. It will be interesting to see how these SS cats pan out over the long run.
Todd said:Well, I have had problems with cracking cats even though my firewood has been under 20% moisture. They still work as long as they are held together in a metal can or frame and could stay intact for years this way before crumbling. I'm still trying to figure out what my problem is along with Woodstock. They keep sending me new ones for free and I asked them about the steel cats, the person stated they looked at them a few years back but couldn't remember why they decided to stick with the ceramic ones. I think it would be a no brainer to go with steel since they are more durable.
gyrfalcon said:Todd said:Well, I have had problems with cracking cats even though my firewood has been under 20% moisture. They still work as long as they are held together in a metal can or frame and could stay intact for years this way before crumbling. I'm still trying to figure out what my problem is along with Woodstock. They keep sending me new ones for free and I asked them about the steel cats, the person stated they looked at them a few years back but couldn't remember why they decided to stick with the ceramic ones. I think it would be a no brainer to go with steel since they are more durable.
For us non-cat owners considering getting a cat, and particularly a Fireview, could you explain what you mean by "as long as they are held together in a metal can"? I literally have no idea whatsoever what to make of that!
My only hesitation about getting a Woodstock is exactly this kind of thing, that I feel like I'm on Mars when I read you guys talking about things like this.
It's reassuring as heck that Woodstock is continuing to send you new ones while you all try to figure out what the problem is long distance, but not having any kind of warm body available to come look at the darn thing and figure out why it might be having a problem is what's really intimidating to me. Whatever "held together in a metal can" means, it's not likely to be something I could do myself.
Peter B. said:Most cats have a light, rigid stainless steel surround or frame around them. I think the main reason is to help preserve physical integrity of the ceramic.
My last (older make) cat was a Corning... and lasted 3-5 years as I recall, but the coating was peeling from the ceramic sub strata (grid/honeycomb) so I replaced it. Results aren't in yet on my current cat (also an old 'hand me down' Corning).
First month of burning and all is well.
Peter B.
Todd said:In the Fireview the ceramic catalyst is contained inside a cast iron 2 piece jacket (metal can) and this jacket sits on an opening to the firebox. If you go to the Woodstock site and click on the cat cleaning slide show it shows this. Woodstock will bend over backwards for you. I didn't even ask them to send me the last cat. They asked me if I wanted a new cat and I told them I'd continue to burn it til it didn't work anymore and a few days later, surprise, the UPS man delivered one. I've narrowed my problem down to overdrafting and use a pipe damper to slow it down, but I may remove my 5.5" liner and just go with the original 6x10 clay tile flue.
gyrfalcon said:Todd said:In the Fireview the ceramic catalyst is contained inside a cast iron 2 piece jacket (metal can) and this jacket sits on an opening to the firebox. If you go to the Woodstock site and click on the cat cleaning slide show it shows this. Woodstock will bend over backwards for you. I didn't even ask them to send me the last cat. They asked me if I wanted a new cat and I told them I'd continue to burn it til it didn't work anymore and a few days later, surprise, the UPS man delivered one. I've narrowed my problem down to overdrafting and use a pipe damper to slow it down, but I may remove my 5.5" liner and just go with the original 6x10 clay tile flue.
Gotcha. I'm calm now.
I know Woodstock has an unparalled reputation for support, but that isn't always a complete substitute for a warm and knowledgeable body on the spot, so I'm still biting my fingernails a bit on this whole idea.
Todd said:Aren't you right in their neighborhood? Go take the tour. You sound just like I did 4 years ago, I was afraid of the bad rep for cat stoves, but bit the bullet thinking if it didn't work out I had 6 months to return for a full refund. No other stove company has that guarantee.
But yes, I do plan to take a trip over there when the weather warms up and I don't have to worry about freezing to death if my ancient Jeep breaks down. I'm not particularly worried about the first six months but several years down the road. When the price of oil goes up again, which it will, I literally will be unable to afford to live here without a functioning woodstove, so it's a pretty criitical matter for me.gyrfalcon said:Todd said:In the Fireview the ceramic catalyst is contained inside a cast iron 2 piece jacket (metal can) and this jacket sits on an opening to the firebox. If you go to the Woodstock site and click on the cat cleaning slide show it shows this. Woodstock will bend over backwards for you. I didn't even ask them to send me the last cat. They asked me if I wanted a new cat and I told them I'd continue to burn it til it didn't work anymore and a few days later, surprise, the UPS man delivered one. I've narrowed my problem down to overdrafting and use a pipe damper to slow it down, but I may remove my 5.5" liner and just go with the original 6x10 clay tile flue.
