4-way wedge compatibility with splitter
dvellone
491
Not certain if this is the correct forum...
Just purchased a Countyline 25 ton splitter and can't find any info regarding the use of a 4-way wedge on this model. I understand some splitters aren't recommended to be used with a 4-way wedge. Thanks
I do not own your brand splitter. But the splitter i own, the manufacturer makes a specific 4 way for it.
You can use a 4 way on any splitter., 20 tons and up, BUT YOU CANT RUN ANY SIZE WOOD THROUGH IT. Example you can take a 10in round and run it through a 4 way, its not recommended to be running 20 to 25 in rounds of oak through one. I wouldnt be running any medium size twisted grain wood through it neather just to be safe. You need to use your head and common sense. Or youll be like some others and bend your beam or break the wedge.. then complain about the manufacturer...ect...I can swap from 4 back to a straight wedge in anout 10 seconds. I would do a search to fined a aftermarket 4 way or maybe someone with a countyline will chime in.. the DHT 4 way is what im using on one of my splitters..
4way wedge
(broken link removed)
there is also a log cradle available
