Finally, I can afford to turn my garage into my work shop with heat. I have insulated the walls, put up OSB boards on the walls and ceiling, filled up the 2 x 8s joist with blow in insulation. Garage is starting to come around. I bought a 45000 btu heater from Menards. on sale plus 11% rebate. I saved $100. right there. Now the question. I'm going to run the exhaust out the side wall because if I go up, the 2nd floor eve is in way plus windows. Out the side wall is a clean shot. Can I use B vent in the horizontal position? Is it safe? I seen the stain less vent also and that stuff is crazy cost.
Thanks for you help. Fespo
