not your grandpa's garn graphs
TCaldwell
the 01-09-12 trend consists of 100lbs mixed cordwood,with o2 control the 01-12 12 trend is 60 lbs mixed cordwood with no o2 control. quite a contrast!
  • [Hearth.com] not your grandpa's garn graphs
Looking for continuing info. Are you able to monitor other emissions during the course of an O2 controlled burn vs no O2 control? such as CO, CO2, etc.? And output during these burns? How are you measuring output? This is very interesting stuff.
jim, damper output is the red line on the o2 graph, dampers are fixed open for the static burn, co2 can be calculated from the o2, I am going to run some spot checks with the testo portable fluegas analyser next weekend for the other criteria on the o2 burn.
