Like most of the midwest we had a severe cold snap the last 48 hours or so. It is early in the season for me, but I took the opportunity to fire up the Oslo for the first time this season. I had already checked the flue and thought I was good to go. However, on my initial load I could not get the temperature up into the operating range. My split and stacked oak is property seasoned and quite dry. Then I thought to check the ash pan; sure enough it was almost full. Once I emptied the pan it took right off and there were no other issues.
Now, let's set aside the issue of how and why the pan went unemptied since last April (and the glass not cleaned either!), and concentrate on the poor performance of the stove with full pan. This is something I noticed the very first season, five years ago. The stove simply will not burn properly with the pan full. I have no interest in resuming the ash pan wars, I simply want to know how it is that some people can burn successfully by leaving the pan full, or even blocking it off, while mine will scarcely burn at all.
I have an excellent, fully insulated flue (6" Excel, full stainless), just over 30' tall with plenty of clearance to all sides that is totally straight up except for the shortest possible 45 deg. offset, clean spark screen, plenty of combustion air, seasoned and dry wood. I can get 500 deg. on the stovetop in well under an hour from a stone cold start, quite good burn times on a load, and good overnight burns - everything you want from a stove. But let the pan get full and even hot reloads will not take off.
I do not classify this as a "problem", I just find it interesting and maybe a bit confusing.
Whats wrong with a simple firestarter?
