First off, it's an existing exterior wall masonry chimney. I'm getting it cleaned soon. There's a damper that may need to come out after 60 years. I found a do it yourself kit of the single wall liner that comes with the cap, etc. You can also purchase separately the insulation and a mesh to keep insulation on the liner. My question is, is this what I want to use, or do I want the actual expensive double walled insulated stainless steel pipe by like 5 feet long, times two, and then a short flexible single liner at the end to pull through an eventual block off plate and snake it to the insert? I just watched a youtube video of a guy using the same kit I'm looking at, but am not sure if it's ok for me to use.
Also, i was wondering if I can snake the 6 inch liner through the damper without taking it out, would it be ok if it went to an oval shape to make it through the damper, since it's not quite 6 inches wide? Or is that a no no, and I must have someone come out for probably $500 and cut this thing out? Thanks guys.
I'm about to order one of the kits. For the princess insert, should I get the normal flex line, or the smooth inside one that's a little thicker I believe? Either way I'm getting the insulation to wrap them as well.
