I'm glad you said it, I didn't have the heart to,trying to be kindler and gentler around XMAS.Mn Dave,
If you really want useful heat for 12 hours you will have to buy a BKK..12 hours is nothing for this stove.
cheers!
cheers!
That's interesting.It is a timed device that gives the stove extra start up air and then shuts it off after the burn is established. Or is supposed to.
He is a fellow sledder..even drives a yamaha..so he can take it..lol.I'm glad you said it, I didn't have the heart to,trying to be kindler and gentler around XMAS.
You will not achieve that with the unit you have,I had the same one 2 years ago when it got bitter below zero with wind chills,minus 15* 5 hours was a stretch with primo wood,a week after that cold spell I chit canned the 5700 and went with a BBK. Good luck.ohlongarm and HotCoals,
Yep Blaze King stoves are the cats pajamas.
If I had known about them I would have seriously considered the King or Princess.
Thermostatic control was one feature that I really wanted. I asked for it at all 3 local shops in Rochester, Mn.
Not one had a stove with thermostatic control and no one mentioned Blaze King.
The ACC feature on Quadra Fire was the closest thing to air control I could find at the time.
Think of the fun I will have trying to squeeze out 8-10 hrs of burn time on a 0F night.
In the mean time I have devised a temporary solution. At around 4 AM I will go downstairs and throw 4 specially selected splits in, set the controls to a little hottler than normal, set the ACC timer and go back to bed. I am very confident that the stove will not overfire under these conditions. The stovepipe damper was instrumental in this.
MnDave
I am 15 hours into a burn stovetop 500,cat 500 plenty of heat still being put out.I just cranked it to #3 and am getting blue flames.I have a 2.1cu ft firebox on my stove and get the advertised 10hr burn times regularly with stovetop temperatures still above 200 and enough coals to relight after 12hrs usually. So I am actually getting better than advertised burn times
As noted above Jotul advertises a 9 hour burn time. Whatever "burn" means.
If I carefully load the stove with nearly full length wood seasoned white oak I can find a really good bed of coals ready to start a new load as much as 11 hours later. On the on the other hand, to maintain a surface temperature above 300 deg. f. for more than five hours would be difficult, I think.
I suspect that most factory test runs are performed with dimensioned lumber to make the tests repeatable and to maximize the amount of fuel available.
I guess 4-6" splits. Mostly Doug Fir cut split and stacked in early spring - so about 9 months dry. I know that's far short of the 2-3 yrs that many people on this site advocate. But it burns great, and no sizzling out the end which is what I got with the "seasoned" wood I bought my first year. A lot of the wood I get has been down for a year or more, so that probably helps the seasoning. This spring I am planning a big push to bring in 4-6 cords and get ahead a year or two so I can see if I get even better burns with 2 yr old wood.Bravo Jim.
How big of splits and what type/seasoning?
Any tips on how to pack the firebox?
MnDave
Amen ,Todd one can definitely get a 40 burn with a BBK,but let's face it your stove is 200*with enough tiny coals in an ash bed to restart. Burn times with heat output on a BBK my experience is easily 12 to 20 hrs. again good enough for me.Both of my stoves exceed manufactures burn time claims. Pretty happy with the overall performances as well.
Some CatBoys have a beautiful clear large window and incredible flames to look at whenever they choose over a burn time that exceeds 12 hours easily....and BK CatBoys seem to also have this when they settle for 8 to 12 hour burn times....they just like there low heat producing extended burn times more than they like a view of the fire....Cats rock. Save wood and are easy to run, heat well and for long cycles. Some are beautiful and exceedingly well built as well...lifetime stoves.
Twelve hour burn times is about the norm for me,during that burn time my house temp will hardly ever fluctuate more than a degree up or down,in the evening when we're up a setting of 2.5 provides as much fire viewing as any other stove brand.Also a ton of heat oftentimes we crack the door a foot or two even when it's in the teens,and stay plenty warm.Once again to all burners, I cannot emphasize the importance of dry wood it MATTERS,in that department I'm a stickler,sometimes I feel guilty burning 3 year old wood,considering I've got 8 year old in the last half of the woodshed that I hope to burn someday.Exactly! When I'm on a 12 hour burn schedule with my BK it throws a ton of heat and the glass stays just as clean as any non cat. Turn it down to a longer burn and yes the glass stays dirty but having the flexibility is what counts for me.
MnDave, how is the damper working out?
