I have a 2200SQFT BiLevel with an outside chimmey and a fireplace 41W26H26D with 6"x26" draft at the top of it and the Fireplace is in the lower level. I have 27"X27" family room down stairs in front of the fireplace with the stairs leading up to the living room and kitchen that is above the familyroom. I just want to help heat the family room and area above it to help offset our electric bill without spending alot of money on a new one.
I found a 35x16Dx25H Buck stove forsale $400 but I can not find anything that gives the dimensions of the older stoves to tell which model it is does anybody know?
Or should I buy a new Napoleon 1401 insert or a new Drolet MDL DB03120
Thanks
Thanks
I fabricated a stack out of 20 ga sheet metal, with all seams welded, to go from the rectangular opening on the top of the stove through the fireplace damper (too cheap to spend the $150 on the one the sell at Buckstove.com!). From there it transitions to 8" round single wall stove pipe up the existing masonry chimney to the top, where I stuffed insulation around the top as well. Then I fabricated a cap out of copper that covers the gap between the flue and the existing chimney. The stove does heat the upstairs as well, if the living/family room is 75, the upstairs is usually 68 or so. I plan on adding a vent in the ceiling near the fireplace that would go via short length (two foot) of flex-insulated duct to my daughter's bedroom, typically the coldest in the house. I can send you a pic of the stove if you'd like, to see if it's similar to the one you are considering.
