Airspace question
RandyG
122
Central Fla
I have a Woodstock fireview ready to install and I am almost finished with my hearth. I am looking at about 18 inches clearance from the rear of the stove to my wall. I installed cement board on sheetrock and then put stone on top of that. My question is I was originally going to leave an airspace behind the cement board but I had a well respected chimney sweep come out to give me a installation estimate and they said I didn't need it and that going directly against the sheetrock with my setup would be fine. Just wondering is this safe, its a little late on the airspace being I'm almost done but I can get rear heat sheild for stove and pipe if necessary, any thoughts?
What does the manual say for clearnace to combustibles? That sounds fine to me without airspace.
I have a different stove, with similar clearnace. I put the heat shield on anyway because I figured I might as well have the added surface of the heat shield to catch radient heat; warming more air and less hearth.
Mike
With an air space you can get as close as 12" It is 18" with rear sheal installed, or 20" from a 3 1/2" masonry wall against combustible wall. 30" from wall without any shields. This is from the Fireview manual. I have the heat shield on mine at at 18" the items behind the stove do not even get warm. To meet the code you must follow the clearance tables for the stove. The rear heat shield looks good on the stove.
Regardless of what the sweep thought, you need to follow the documentation. Do you see an exception for your type of installation in the manual? If not, I'd get the rear heat shield to be legal and safe.
  • [Hearth.com] Airspace question
