Alaska cabin - boiler vs wood stove?
Log Home
74
The forest
For an off grid log cabin kit build in interior Alaska, 1,800 square feet, 2 floors, 3 bedrooms, 1.5 bath, well, septic tank, solar system with backup diesel generator, I'm trying to decide on the main heat/fuel source for the cabin between wood logs vs coal, and a wood stove vs boiler, and which will be the most efficient cost effective reliable option. I want the heat source to be centralized in the center of the cabin.
I've read about and seen videos of the DS Stoves Energy Max 160. I like the fact it's a dual fuel non-electric furnace that burns wood logs and coal and can heat water throughout the house in a thermosyphon system and be connected to a hydronic system for floor and base heating and it's placed indoors and not have to go outside to feed/tend to it. Are there any non-electric stoves/furnaces/boilers superior to that for burn times and efficiency with similar features that is a "set it and forget it" with those 48+ hour burn times if that's possible ?
My concern with an outdoor boiler is feeding/tending it when it's negative -58 below zero F outside and seeing some YouTubers who have outdoor boilers they mention how much wood they consume, sometimes over 10 cords a season.
I've thought about having two different separate stoves installed, one would be the main centralized heater would be a large boiler/furnace style stove and the second a wood stove in the corner of the family room (Blaze King Princess 32).
If you were in my shoes starting from scratch and working with the contractors/builders how would you setup a log cabin from the ground up to be the most efficient and comfortable to make it through the cold winter months as smooth and as easy as possible with the least problems?
