Hello , I am new to this forum and having been looking on here for days. The Garn is really getting me excited. Like my title says OWB are the latest craze in my neck of the wood so I can't get any info on gassification boilers from friends and neighbors . I have used the search function on this forum but I still have quite a few questions.
Here is a little info on what I will be heating : 1624 sq. foot home , 28X28 attached garage , 24X32 garage and hot water for the house.(the heat in the garages only need to be heated to 45 F or so to keep the chill off) House was built in 2001 and insulated well.
Heating with forced air gas furnace\heat pump now. I would like to locate the Garn in the 24X32 garage which is about 120 feet from the house
Questions
1. I am thinking of placing the unit in the 24X32 garage that is 120 feet from the house , if I insulate the Garn with a mineral wool style insulation should it be insulated well enough setting out in the garage ? Didnt know if I had to frame in an area of the garage and insulate heavily ?
2. I understand I will need the PEX pipe , heat exchangers , blowers ,and fittings , what other high dollar parts am I overlooking ? Pumps included with Garn or not?
3. Looking purely at the installation side of things other than needing to be inside a building and being insulated are there any other differences in hooking a Garn up vs. hooking up a standard run of the mill OWB ?
Thanks in advance
Questions
Thanks in advance
