I have had trouble getting heat out of my Drolet Escape 1500 all year. I do not get the STT that I think I should get from this stove. And thus, I do not get the heat in my house that I expect to get.
I ran a test last Friday when it was 23 F outside and no wind. My stove top to chimney cap is 12 feet. I had just installed a manometer and a damper.
My goal was to try to keep the flue temperature around 750 F.
I got the fire up and going and for 3 hours the flue temp was between 700 and 800 F. It would fluctuate, but I did not chase the temperature by adjusting the primary air. When it did go below 700 F one time, I did a slight adjustment which brought it back into range.
My manometer stayed in the .07 range.
I never adjusted the damper. It was full open the entire time.
Here my concern: The STT never got above 485 F. That happened about 2 hours into the test.
Is this all I should expect? Should I expect more heat to transfer to the stove top and then into my room?
Thanks for any thoughts.
