I've been wondering this for awhile. Those with storage, how do you get your boiler to shut down the pump or loading unit after the storage is hot top to bottom?
For Example:
I load up the boiler, fire it up, boiler temp hits 160, pump launches, gasification for three hours or so, and as the coals are consumed, and the flue temp drops below setpoint, fan turns off. Pump runs till boiler is down to 155 (160 pump launch - 5 pump hysterisis), then residual heat launches pump again at 160, load only returns water at 149 (min return temp) and after 10 min of very little heat drawn from boiler due to margional delta allowed by min return, boiler back to 155, pump turns off.
This cycle repeats itself usually about 5 times, or around an extra hour of total pump run time with little heat drawn from the boiler. I with I could set the pump launch higher than 160, as the min return temp is a high 149F (65C) which is only 6 degrees below pump drop out temp. If I set the pump hysterisis lower it cycles during ramp-up, I thought 5 degrees was a bit narrow. Any thoughts? I hope this all made some sense......
TS
For Example:
TS
storage temperature rise out of a burn, if the house isn't sucking up too much of the heat as you go. How many gallons is your storage tank and what are you typically burning to get that result?
