Hello
Picked up Pelpro HHPP2BD - 120 lb Hopper Pelpro pellet stove.
(broken link removed)
It has the latest digital control panel that works well with a T-Stat.
The combustion blower is really noisy and I have to swap it out but looks like the standard 3,000 RPM size blower.
The reviews are overall good with the damper adjustment a little too course and the heat output a little low on lower heat settings. It does use 1.5 to 5.5 lbs per hour going thru heat settings 1 - 4.
I called Danson and the tech support guy stated 110 Deg F out of the heat exchanger tubes is normal.
It has a 265 CFM convection fan which is really enormous and much higher than 150 - 165 CFM of other stoves with similar burn rates.
Therefore, as a test I was thinking about adding a rheostat on the room blower to tone it down a bit and do some heat testing.
Any other ideas?
Any other ideas?
