Another Woodstock vs Hearthstone question
Malarky112
14
CT USA
Hey everyone,
[Hearth.com] Another Woodstock vs Hearthstone question
Which stove should I choose? Looking for updated opinions since a lot of threads I saw are older now.
Replacing a 90’s VC Encore, needs too much work and want to replace before the tax credit expires. Stove is in my living room on 1st floor, it’s gets pretty hot in there so I was hoping soapstone would help lessen the blow a little. Wanted a hybrid since we need long burn times for overnight and when we’re all at work (8-10 hours). We have electric heat so stove is PRIMARY heat source and it needs to run without issue, almost 24/7 from late fall to early spring.
Live in NE corner of CT, house is a cape with 2nd floor. Honestly most the time we don’t heat the 2nd floor as all living is done on first floor. Roughly 2200 sq ft total house.
I think I have settled between a Woodstock Progress and a Hearthstone Heritage or Mansfield.
So far I am leaning towards the Woodstock. I can’t find really any complaints online about Woodstock stoves where I see plenty of complaints about Hearthstone.
I wasn’t sure if they’ve addressed some of their common issues in newer stoves. I was going to email them but no way to contact them on their website, they want you to talk to a dealer. Woodstock on the other hand has had no problem answering my 20 questions so far.
Positives for Hearthstone is I have a dealer 30 mins away and a mutual friend is a salesman there (he did say hasn't heard good things about Woodstock stoves, no dealers for parts...but I take that with a grain of salt). Prices would be very similar between all 3 choices. Also if I go with the front loading HS Mansfield, I believe my current raised hearth would have all the proper clearance. If I go with a side loading Heritage or WS Progress, I would need to address side clearance, most likely by adding a hearth pad along that side. I also have a coworker who has been happy with his noncat Hearthstone.
Delivery for the HS would probably be easier, but I do have a local safe company willing to take delivery of the WS for me and I could pay them to get it into my house. HS dealer also offered 10% off if I pick up instead of delivery. I like the looks of the HS a little better but not enough to persuade me to change my mind if WS is the more reliable stove.
So, lots of details there but help me decide! Any advice on my hearth would be welcome as well. I read on here that a rasied hearth counts for more clearance, can anyone confirm that? Thanks so much for any replies or advice. I have been researching myself crazy for about 3 weeks now but its such a big purchase and an important part of our house that I need to make the correct choice!
Check clearances. It looks like the Encore is too close to combustibles and the Progress has higher clearances as well.
With living in that part of the country I'd for sure buy a WS, I know quite a few people that have them, heat almost totally with wood, and are diehard WS fans. (most had other brands before too, so not first timers)
Get it quick, prices will be higher this fall.
Thanks. They’re good, except maybe the wood rack I have next to it. It’s hard to tell but it has a rear heat shield on it.
Yes, the wood rack is too close. The new stove will also have clearance requirements. They need to be checked first. In the case of a side-loading Progress Hybrid, the hearth may need rebuilding to meet requirements.
If I go with a side loading Heritage or WS Progress, I would need to address side clearance, most likely by adding a hearth pad along that side. If I was to rebuild I would take the whole thing down and use a bigger hearth pad, I’ve never been a fan of the raised hearth, especially now that my kids are grown.
If you can change in/change out with the Mansfield, it will be a good stove to go with. Hearthstones are nice stoves, always thought the non cat version Mansfield was a great stove, the only issue if you mistreated the door handle, it could fail you. The rest of the stove is solid. The WS's are nice stoves too. I think if I had to redo-redesign the hearth though, you're bringing more cost into it. Good luck, I'm sure you'll like either stove.
If you are going to have a raised hearth, raise it! Make it high 12-18" tall, so you don't have to bend down so far to load/etc! (assuming the flue/chimney height will allow it)
I had a hearthstone noncat and upgraded to a BK cat stove on the same hearth. The HS stoves always have been very good looking but not high performance and their durability from the late 2000s sucked. They would heat the home for a while but their real emphasis was aesthetics. Woodstocks are all pretty weird looking but have an emphasis on high performance and were designed and built to be proper cat stoves with relatively long burn times.
The IS model from WS is a front loader and with stone inner bricks along with the ability to burn on low output might work well. Not stone on the outside though if you really want that look.
Given the two brands, and to answer your questions, I would choose Woodstock all day long and rip that old broken down hearth out in any case. It's time for a new one.
