So, I've posted this diagram before, but now there have been some modifications, so let me explain first:
I live in a tri-level home built in 1979 (2100 sq.ft). The mid/main level (kitchen/dining room/living room) is 840 sq. ft with a a partial basement (640 sq ft.) underneath where the woodstove is. Since I made the diagram above, we are in the process of putting in stairs into the basement directly inline with the stairs you see on the diagram that lead to the upper level (bedrooms/bathroom). We have a vent directly about the stove, and the cold air returns labeled are no longer in use (the crawl space they dropped into is now sealed off with drywall and R11 on the one side of the stairs). The stove is an old Shenendoah, and with the stairs cut in, AND an EdenPure running on the main floor, I can keep the temps at 70-72 degrees (much better than before the stairs were in) unless the temps drop into the single digits.
So far, compared to last year, we're averaging almost 20KWH per day less during December and January with this current setup. Granted, our electricity was deregulated last year, and rates went up (I'm currently paying $.095/KWH). During December, our average temp was 40, compared to 45 in 2009, and this year we used 1781KWH. During January, our average temp was 27 (With a few days in the low single digits), and we used 1141kwh (remember, this was the first month with the stairs in place).
I'm still not happy that I have to run an edenpure to keep temps truly comfortable, so I'm wondering what's next. Am I better off buying a new, high efficiency stove rated for let's say 3000 sq ft, and HOPE that it does the trick (where the stove is now, the majority of the chimney is on the exterior of the house (it's a stainless line), or I'm also considering a ductless heat pump for the main floor to supplement. All I need to do is keep the main floor at 70 close to 24/7 as possible.
The way I look at it, the ductless system costs a lot more initially, but will add to the resale of my house (right now, it's just baseboard, the woodstove, and the gas fireplace on the lower third level family room). It will also cut down on my initial wood needs (wood is free as my parents own 90acres 1.5 miles away), but I really think I've been under supplying myself with wood (I really think I need about 6-8 cords to burn as heavy as I will need to keep the temps where I want it), and the ductless system would lower the pressure of me needing to get all of the cords cut and ready each heating season.
I'm at a crossroads at this point, and I'm not sure really what to do. Thoughts?
