So, we just moved into a nice '54 mid-century mod ranch in 2020. House has stacked fireplaces, one in the basement, one on the first floor. Whole structure is between house and garage. First winter we did a few fires just as is in the basement, was OK but not a whole lot of heat (bit dangerous for my 1 & 3 yr olds), but my inlaws offered an older insert and my father in law was going to help install the liner and everything (former gen contractor). This fall we had all the pieces and he came over, built a platform to work on up on the roof and we started trying to install the liner.
First prob, OG clay liner is something like 8"x10" and the 6" steel liner + insulation was not wanting to fit (especially since much of the mortar was allowed to drip out the seams). We finally started pulling the steel liner down when we ran into prob 2: I have about 135 degrees of bends in that chimney. In the chimney stack this is the far one: so it goes down past the first floor fireplace (middle of stack), 45 degrees to re-center itself, then another 45 to straighten up, then a 45 to get to the smoke shelf. We were not going to be able to get that liner, with or without insulation, through all of that.
We were just going to do a direct connect but our brick façade is too thick and we can't even get the insert to line up with the short liner we shoved up there. (I was a little miffed at my FIL because I wanted him to come do the measurements before hand so I could order all the right parts and get things right and if he had we probably wouldn't have spent close to a grand for all the materials, but also my 60 yr old FIL came & worked on my roof on a day off, worked himself like a dog, and was frustrated that this stove he gave us was going to do us no good, so it is what it is).
Any advice from that? We were going to hack up the stove to see if it would go back far enough and just do the direct connect, but further measurements proved that wouldn't work. Looking at something like Vogelzang Wood Stove Insert where the flue connector is at a 45 so we don't have to worry about depth of stove, but that still leaves us at direct connect.
Bonus question: our chimney stack has 3 chimneys for 2 fireplaces, one of them (the one not connected to a fireplace) is blocked off. Any ideas of what it is?
