The house I recently purchased was a typical cookie-cutter 2 story, full basement house constructed in early 2000's by a contractor who decided to use a fireplace insert and a double wall lined stainless steel flu. Additionally, he decided to install a powervent boiler thus eliminating the need for another flu. The one thing I hate about the house is these two setups.
What I WANT to do is install a 3 flu chimney. One flu for the boiler (In basement), one flu for a future wood boiler and another flu for a wood stove on the first floor (fireplace insert is going bye bye). I've been scratching my head with two options. Option One is running the chimney up the inside of the house, in the cavity where the stainless steel flu pipe is. I understand this will require additional structural work but I'm prepared to do so. The 2nd option is adding a 3 flu chimney on the outside of the house and coring through the foundation for the to the two flues for the oil boiler and future wood boiler. Then using a thru-wall thimble for the wood stove on the first floor.
The problem with Option 1 with a 9" wide flu, 1" airspace, 4" fireblock and 2" between combustibles, I would need a 23"-24" cavity. I've measured all the way up. I have those clearances until I get to the attic where there is 21-1/2" between the topplate of the 2nd floor wall framing and the bottom of the 2nd roof truss (24" O.C.). Is there a material I can place to protect the wood framing?Is there a slightly thinner brick?
The Problem I have with Option 2 is what kind of clearance is required between the chimney brick and the sheathing if I can go up the side of the house? And is there a good way of flashing the sides of the chimney to the sheathing? Does the chimney get anchored to the house framing?
