sportbikerider78
Awesome. Make sure to post some pics of your setup when you are done. Don't skimp on the technical details (driver, how you did the wiring...ect), we are interested.
Great post, Rusty! However, as someone who designs things that get wired, let me point out there's still good reason to go heavier than 18 gauge. Landscape wiring is exposed to abuse, such as accidentally hitting it with gardening tools, tugging, roots, etc. Heavier wiring, while not required for voltage drop / capacity, is always more durable.3. You can use 18 gauge wire *IF* you stick with LED bulbs. Much cheaper and easier to work with, compared to 10- or 12-gauge wire...
...lots of vendors sell "warm white" LEDs, but they're maybe 3000 CCT (the lower the warmer) whereas you want 2700 or less.
Thanks.... there's still good reason to go heavier than 18 gauge.
How far ? Could maybe run 12v, if you use LEDs out there 18ga should be fine, but like Ashful pointed out above, it needs to be landscape-light grade (or equivalent) so it has heavy enough insulation to protect it (still, rubber is cheaper than copper).It's getting dark pretty early now, so I was thinking about adding some LEDs to my wood shed so I can still fiddle around out there.
Too far from the house to run AC so I am considering either solar powered or battery powered LEDs. Probably just one or two, don't need tons of light, and might only use them a few hours a week. Any thoughts?
Doesn't sound so bad to me. You gotta do that, or do something solar, or just batteries that have to be replaced fairly often. For solar, you might be better off with a little solar panel which charges a small 12v battery for overnight. I'm not sure - I've never set up a solar system - but you might need some sort of controller too.It is probably 150' from the house.... rather not run wire across the backyard and through the woods.
Maybe there are some that don't suck, I don't know.I know those little path lights with the tiny panel on top get a bad rap, but wasn't sure about the other style.
Ingenious!When I want to work at the shed at night time, I just bring out the flashlight and place it in the fixture.
Looking at those LEDs on the picture above, I'm thinking they are not adequately heatsinked, so that's what caused the premature failure. LEDs are normally reflow-soldered onto tiny metal-core circuit boards (MCPCBs) called "stars"; even though the star is actually meant to be the interface to an actual heat sink, I find these provide enough heat dissipation by themselves when I'm running at about 1/2 watt, and certainly more heat dissipation than what I'm seeing in that photo..Update on the path lights: two of the six LEDs stopped working maybe a month after installation.
Neat, but why not just gas up the Coleman lantern? I always smile when I fire up mine, which reminds me of camping as a kid, and it's a great light for working at night.Few updates...
For the wood shed light, I decided to make sure of a super bright rechargable LED flashlight and an old plastic lamp globe I had hanging around. I made up a little bracket that holds flashlight right above the globe and mounted it to the shed:
When I want to work at the shed at night time, I just bring out the flashlight and place it in the fixture. The globe really helps diffuse the light... hard to photograph, but the middle shed bay is very bright and the two side bays are decently bright. Definitely bright enough to split/stack wood.
Update on the path lights: two of the six LEDs stopped working maybe a month after installation. They are the two first in series after the power supply, but might be just a coincidence. I haven't gotten around to replacing them since the other four still give off enough light to illuminate the path. The other four are holding up well... were covered in snow for a week or two and they kept on glowing. I have run into/over a few of them and they are super easy to stick back into the ground, no permanent damage.
