Looks like a larger version of the F50 stove.. I like this stove! Couldn't find info on the firebox at Jotul site. Wonder what the MSRP is going to be.. The warranty looks great too. Very similar to the T5 I run here..And is this pretty much the same stove as the F50 Rangeley? Looks like it...
That is a big stove! Does that MSRP include the cast iron skin? If so that's a decent price.. Ash pans are something I don't care about and don't use on my T5..Firebox is listed as 2.95. They were able to raise the baffle since it doesnt have a a top load mechanism. The foot print is exactly the same as the
TL-50. MSRP is $2,199.00. The other difference is there is not an ash pan on the F-55.
No gasket on the T5 ashpan Todd but I don't use it anyway.. Shovel into ashbin works just as well...The 55 was on my short list, sounds like a solid low maintenance stove. Ash pans usually require more gasket involvement also. Todd
Ran a cat stove for 2 decades and like them both for different reasons. I do prefer watching the secondary burns and my burn times are surprisingly long and better than expected..It also only requires ember protection... I just wish it was a cat stove
Welcome to the forum VT and thanx for the info! Please post some pics of your stove/hearth when you get a chance I suggest burning larger splits to reduce the offgassing and high peaks with good dry hardwoods.. Smaller splits get very hot quickly and can be harder to control.. BTW the T5 firebox is a clean rectangle and loads easily with no obstructions..I have run the F55 for a couple weeks now...sold my Oslo. Like that I can load EW and NS. I'd say the claimed firebox volume is pretty accurate...loading NS I can cram almost 2.5 cu ft (16" splits) on top of a coal bed (~2 cu ft EW). I too have a strong draft and the secondaries have gotten away from me a couple times while burning NS with the air control shut down at ~300* stove top (stove top temps hit 650*-700* for a good hour plus until secondaries started to slow down)...still seeing if I can get better control by shutting down the air sooner to avoid off gassing the whole load at once...possibly a different mix of wood (some of my wood is maybe too dry ~12% moisture). This has not really been a problem though as the outside temps on these nights (in the low teens and upper single digits) warranted the extra heat and the burn time was not significantly affected. It would be nice if the firebox was completely square (as previously mentioned the back firebrick protrudes ~1" into the firebox on each side making the back 4-5" of the firebox ~2" narrower than the front). Loading NS and EW I have not had a problem keeping ~1900 sq ft of my house (built 1980 with average ceiling height ~11-12 ft., somewhere between tight and drafty) toasty on 2 loads/day (ash/maple/cherry/other mixed hardwoods). I get about 8 hours useable heat (stove top >/= 300*) and have no problem starting from coals up to 12 hours later. A few nights ago (with temps in the low teens) I loaded up NS at 8pm with the stove room at 71* (upstairs bedrooms 67* - 70*), was cruising at 500* by 9pm...when I got up at 6am the room temp was 69* (bedrooms ranged from 62*-67*), stove top was ~200 and there were plenty of hot coals to throw in a full load and have her cruising by 7am. I think with a little more time with the stove (possibly a damper to reduce the draft on those really cold nights) this stove will be everything I dreamed it would be...for the price I don't think I could be happier!
How big is your house?It also only requires ember protection... I just wish it was a cat stove
Will have to wait until it is not in use Dutch maybe tomorrow?Ray
Would you be able to take some rough measurements of your firebox for comparative reasons?
I would say it is in between the T5 and T6 but cu. footwise closer to the T6. The T5 is 2 cu. ft. and the T6 is 3 cu. ft. with the T6 being wider and more square than the T5. OK here are the dimensions:At your convenience Ray, no hurry at all. I'm just curious whether this stove is closer to the T5 or T6.
I just started running the F50.....had a VC encore cat stove for 7 years before.It also only requires ember protection... I just wish it was a cat stove
Ray
8+ hr. burns is easy with this stove..What are you seeing for times Ray?
You may want to consider the T6 or the Jotul F55 with that size home and it tends to get a bit colder there. Hard to say but the T-5 might work for you.About 1900. The end of the house that I am looking to put a stove in has one large room, approx 525sq, with 13' cathedral ceilings. I am going to put it just outside of this room (it flows into a common area then into the rest of the house). That large room is probably 50% windows (Ill up a picture at some point)... room definitely chills of. My stoves main purpose will be to heat that room, and of course whatever else I can draft through the house... all the better.
