Some of you may remember I had trouble with my old Ashford and spent quite a bit of time and money getting a better draft, changing bolts under the gasket, trying different gaskets, etc. to try to get rid of the smell. Well, I now have a new Ashford in my new home and have the same issue, this time, draft is NOT the issue.
I think I have it at least narrowed down to the hinge on the door. I have read that other BK owners also complain of the smell coming from the left front. With the top off, I can really isolate exactly where it’s emitting from laterally and it’s different than with the top on, obviously. As it rises up, it gets pulled in whatever direction and can lead us to believe its coming from elsewhere. With the top off, it’s right over the hinge and nowhere else. As the fire burns back and away from that area, the smell goes away.
Another interesting new observation on this brand new stove is that after my first few warm up fires, I was giving the stove a once over and noticed the door, when latched, could be pressed upon and there was give indicating that the latch was not that tight. So, l tightened it very slightly which brought the latch to a more secure feel. No play when pressing on the door. Would you guess that the smell got worse!? My theory is that since the latch pulled the door more tightly closed on the latch side, it exasperates the issue with the hinge, bowing it further out from the knife edge causing the release of the smell.
I just wanted to let everyone know my experience. I obviously love the stove enough to rebuy it, but God I hate this smell. My new neighbor actually loves the stove and is in the market but he can smell it so is turned off. If anyone has a fix that isn’t the same old draft argument, Id be very grateful. My new setup is as follows: 25’ straight up, double wall, OAK, no fan kit, yet. I burn everything from cedar to white oak, MC 15-18% with most everything, sometimes lower. I burn every load for at least 10mins before I engage the cat, sometimes longer if my chimney isn’t getting too hot. House is 2200sf. Stay warm everyone!
