Avalon Olympic insert advice please ?
greenwytch
3
northeast PA
hello everyone,
Hope i'm doing this forum thing right to ask some questions. We just recently bought a new (old) home with an Olympic Avalon insert. I've been through the manual a bunch of times and am trying to get the hang of the operation. What i can't find in the manual is how do you know when it's time to add more wood and how much is safe to put in at one time? Thanks in advance for any help on this.
Welcome to the forum!
Not sure if this particular insert is a current model or old, but sooner or later someone with an Avalon Olympic will chime in, I am sure. If you modify your post to reflect that you are looking for advice on that particular insert, you will likely get more hits.
In any case, check in your manual to see if you have a secondary combustion air supply to your stove and/or if it is EPA certified. If so, then you will want to start your fire with primary air only (i.e. lots of air initially). Then, when your stove top gets up to about 500 degrees F, slowly over a period of 30 minutes or so reduce the primary air which will also increase the secondary air. This will slow the burn down to extend the temperature over a longer period of time, and also result in the cleanest burn with the least smoke and less chance of creosote forming in your chimney. As you get more experienced, you might find that you can shut the primary air down faster, or if your wood is not dry enough, it may take longer. You'll know you have secondary combustion when the flames are purplish and coming from the top or the middle of the stove.
As far as how many splits to put in, start small. You need a minimum of three splits, and four is better. Make them small splits in the beginning as you learn your stove. Reload when the stove top temperature falls to about 300 degrees F and you have just coals. As you gain experience, you might re-load earlier and hotter, but I wouldn't do that yet.
If you don't already have a stove top thermometer, you'll want to get one from your local hearth store.
Good luck with your insert, and take it slow.
Basically you add more wood when the stove's temperature output has dropped because the fuel load has been mostly burned up. There should still be a hot coal bed of maybe 1" deep, but not 4" deep. It takes some practice and experimentation to get used to the stove. The main thing to avoid is putting a lot of smaller splits (say 2-3") on a large hot coal bed. That would take off like a banshee and the fire + heat would be significant and possibly out of control until the fire settled down. Instead, try adding larger splits (6-8") on a moderate coal bed to ignite slower and to be easier to control. Start closing down the air in stages once the new splits have ignited and are fully aflame. A thermometer is good to have here as it gives a measurable temp to correlate with air reduction. Depending on the stove and the wood you may want to start decreasing the air supply when the stove face is around 450 °F maybe down to 50% closed. Then continue to close it down in increments until the flames get lazy and waft, but don't go out.
This is a pretty easy to run stove. Here's a couple articles that should be helpful:
https://www.hearth.com/econtent/index.php/articles/tending_a_wood_fire
https://www.hearth.com/econtent/index.php/articles/burning_wood_better
and
http://www.ec.gc.ca/cleanair-airpur/default.asp?lang=En&n=8011CD70-1 - watch the video
DBoon - i've got an Olympic 1190. I've got just the air control on the bottom and the bypass control on the top and the manual doesn't mention anything about secondary combustion ? I put in 3 splits (i didn't think they were too big) and it sure made a lot of flame - is that something that's okay? I read a few things on the forum where folks stacked quite a few pieces into their wood stove, so that leaves me a little confused. Believe me, i have a healthy respect for fire, so forgive me if i sound lame, but i'd rather not make any mistakes on this. Thanks and happy new year !
Does being an insert rather than a freestanding stove make any difference in loading, amount of wood, etc. ?
Grab a thermometer from Rutland and put it on the stovetop. This will help you burn your stove a little better. I had the Olympic...I miss it badly but I simply could not have 2 woodstoves in this time of my life. But my father in law has one and the secondary burns are very impressive, actually the nicest I have seen so far. You can surely load 3 splits, east to west preferably. Always open the top bypass damper before you load her up, this will open up the stove and stop an puffbacks that could happen when opening the door. After the bypass is open, open the door and load 2 or 3 splits, char the wood and shut her down to about 15-20% open, pulling out the main air adjustment. This is too be done with a good bed of coals of course. Initially you want to heat up that stove with smaller pieces to get it to around 500-550F, having the primary air adjustment all the way in during that first burn of the morning/day.
This stove is simply remarkable, one of the best I have seen and I have been envious of many stoves....my name is JFK and I am a wood stove addict..
Enjoy!
I have the olympic and am very happy with it. do exactly how jfk explained and you should have no problems. make sure you get a temp gauge, when it gets goin close the bypass and choke er down. this stove cruises and i'm sure you will be very happy when you get use to it. might want to get the chimney swept if you have'nt already since it's a new house. Happy New Years everyone!!
