Best place to buy Double-Wall Insulated Chimney Pipe - Class A
The BK can only be bought at a dealer, if new.
Class A is by definition double wall.
I think Rockford chimney supply is a good vendor too for chimney supplies.
There is Duraplus Class A triple-wall chimney too. Not recommending it, but it's out there.
There are several online outlets for chimney and stovepipe. Northline Express.com and Woodstovepro.com are a couple others.
Reactions: stoveliker
I ordered a double walled telescoping stove pipe, not class A chimney, from Menards last year, first and only time dealing with them. I was very satisfied with their customer service. The pipe came through slightly damaged. Contacted them. The rep asked for a photo and had a new one shipped right away.
Reactions: Teachme
Well if i do as you guys think is best and take out the old pipe i will have a 12inch hole same size and ready for Duraplus Class A triple-wall.
Is Duraplus Class A triple-wall better or worse then the double I would think its better just more $. How is it to instill vs the dura tech
DuraPlus is DuraVent's value line. It's not a terrible chimney pipe, just a less expensive grade and uses an outer air layer to supplement the inner insulation jacket. Both DuraPlus and DuraTech are straightforward to install with good mfg. directions.
I got mine from the local hardware store. They had better prices than online.
Reactions: Murray01
the 3 wall DuraPlus by DuraVent is more money then the DuraTech 2 wall....
That doesn't sound right. Someone may have their pricing list messed up or they are not the same outer metal. DuraTech is available with a galvalume outer jacket.
DuraPlus has always been their value line. Make sure that the length, diameter, etc. are identical. The fittings, like a Tee are where the difference really shows up.
[Hearth.com] Best place to buy Double-Wall Insulated Chimney Pipe - Class A[Hearth.com] Best place to buy Double-Wall Insulated Chimney Pipe - Class A[Hearth.com] Best place to buy Double-Wall Insulated Chimney Pipe - Class A[Hearth.com] Best place to buy Double-Wall Insulated Chimney Pipe - Class A
Reactions: Teachme
View attachment 299238View attachment 299239View attachment 299240View attachment 299241
I was just going off this
BRAND FEATURES​
    • Most Recognized Brand in the US.
    • Best Durability and Longevity.
    • Best Warranty, Customer Service & Tech Support.
    • Rated Best Product Based on Customer Reviews.
  • Hide Features ▴
  • PIPE CONSTRUCTION​
    Double-wall pipe
  • INSULATION TYPE​
    Thermal Tech blanket insulation
  • MATERIAL TYPE​
    • .020” 430 stainless steel inner wall
    • .016” 430 stainless steel outer wall
  • INSTALLATION​
    Professional Recommended
  • * MOBILE HOME USE​
    YES
  • ADDITIONAL FEATURES​
    No locking bands or mechanical fasteners required
  • Limited Lifetime Warranty
  • [Hearth.com] Best place to buy Double-Wall Insulated Chimney Pipe - Class A
    Made in USA
See Parts List
Subtotal: $2603.70
** Would you like to include a chimney adapter?Select option...Single Wall Black - Slip ConnectorSingle Wall Black - Snap-LockSingle Wall Black - DuraBlack Chimney Adapter w/ TrimDouble Wall Black - DVL
BRAND FEATURES​
    • Best for mobile homes.
    • Best Insulation.
    • Best draft.
    • Our recommendation for any mobile home installation.
  • Hide Features ▴
    Triple-wall pipe
  • INSULATION TYPE​
    Ceramic blanket plus air space insulation
  • MATERIAL TYPE​
    • .016″ 430 stainless steel outer wall
    • .018″ aluminized steel intermediate liner
    • .016″ 430 stainless steel inner liner
  • INSTALLATION​
    DIY
    YES
    Made in USA
See Parts List
Subtotal: $2984.92
BRAND FEATURES​
  • Hide Features ▴
    Double-wall pipe
  • INSULATION TYPE​
  • MATERIAL TYPE​
  • INSTALLATION​
    YES
    Made in USA
See Parts List
Subtotal: $2603.70
BRAND FEATURES​
    • Best Insulation.
    • Best draft.
  • Hide Features ▴
    Triple-wall pipe
  • INSULATION TYPE​
  • MATERIAL TYPE​
  • INSTALLATION​
    DIY
    YES
    Made in USA
See Parts List
Subtotal: $2984.92
Dura plus is a far inferior product regardless of price. It has half the insulation so it looses much more heat. The cooling jacket can cause drafts. Wasps etc also love to make nests in the cooling jacket leading to an unsafe condition. It takes more space. And probably other reasons I am not thinking of
Reactions: Teachme
But quite honestly I wouldn't use either because of the 430 inner wall. I would want 304 or 316 inner
Reactions: Teachme
so what brand would u go with?
BRAND FEATURES​
    • Premium grade stainless steel construction
    • Smart choice lifetime warranty
    • Mobile Home Installation Approved
    • 1" Mineral Wool Fiber Insulation
  • Hide Features ▴
    Double-wall pipe
  • INSULATION TYPE​
    Solid-packed insulation
  • MATERIAL TYPE​
    • 304 grade stainless steel corrosion resistant inner liner
    • 304 grade stainless steel corrosion resistant outer liner
  • INSTALLATION​
    DIY
    YES
    Best for installations near ocean or salt water
    Made in Canada
We were unable to find the following parts for this brand:
  • Roof Flashing
You may consider purchasing another brand or continue adding available parts to your cart.
See Parts List
Subtotal: $2032.42
** Would you like to include a chimney adapter?Select option...Single or Double Wall Adapter
BRAND FEATURES​
    • Mobile Home Installation Approved.
    • Added Connection security with locking bands.
    • The coolest under even the hottest conditions.
    • Compatible with all Metalbestos chimney systems.
  • Hide Features ▴
    Double-wall pipe
  • INSULATION TYPE​
  • MATERIAL TYPE​
    • 304 grade stainless steel inner liner
    • 430 grade stainless steel outer liner
  • INSTALLATION​
    DIY
    YES
    Made in Canada
  • Roof Flashing
See Parts List
Subtotal: $2159.48
BRAND FEATURES​
  • Hide Features ▴
    Double-wall pipe
  • INSULATION TYPE​
  • MATERIAL TYPE​
  • INSTALLATION​
    DIY
    YES
    Made in Canada
  • Roof Flashing
See Parts List
Subtotal: $2032.42
BRAND FEATURES​
  • Hide Features ▴
    Double-wall pipe
  • INSULATION TYPE​
  • MATERIAL TYPE​
  • INSTALLATION​
    DIY
    YES
    Made in Canada
  • Roof Flashing
See Parts List
Subtotal: $2159.48
I use ventis or Jeremiah's. But Selkirk does make some nice pipe. A welded seam will keep weather out better than crimped seam
Reactions: Sim
Hi Bholler, are you still using Jeremiahs and happy with it? Im considering using this chimney pipe. Also what stove pipe do you use? I dont think jeremiahs makes any or at least I cant find it online. Thank you
+1. I was recently in a general store. I guess it’s a hardware store, but they have an incredible deli and sell stuff like bags of donut filling. They had boxes of pellet vent on their upper shelves. If you weren’t looking up there you’d never know they had it.
They’ll appreciate the business and next time you need a 3/8” fender washer you’ll be able to get one!
Reactions: Burnin Since 1991
Yes Jeremiahs is my favorite chimney so far. Not the easiest to install but the best finished product
