Is there a better place then others to buy Double-Wall Insulated Chimney Pipe - Class A
Or for that matter a BK King 40
There is Duraplus Class A triple-wall chimney too. Not recommending it, but it's out there.Class A is by definition double wall.
Well if i do as you guys think is best and take out the old pipe i will have a 12inch hole same size and ready for Duraplus Class A triple-wall.There is Duraplus Class A triple-wall chimney too. Not recommending it, but it's out there.
There are several online outlets for chimney and stovepipe. Northline Express.com and Woodstovepro.com are a couple others.
the 3 wall DuraPlus by DuraVent is more money then the DuraTech 2 wall....DuraPlus is DuraVent's value line. It's not a terrible chimney pipe, just a less expensive grade and uses an outer air layer to supplement the inner insulation jacket. Both DuraPlus and DuraTech are straightforward to install with good mfg. directions.
That doesn't sound right. Someone may have their pricing list messed up or they are not the same outer metal. DuraTech is available with a galvalume outer jacket.the 3 wall DuraPlus by DuraVent is more money then the DuraTech 2 wall....
![[Hearth.com] Best place to buy Double-Wall Insulated Chimney Pipe - Class A [Hearth.com] Best place to buy Double-Wall Insulated Chimney Pipe - Class A](https://www.hearth.com/talk/data/attachments/299/299265-a96611085ecbb16abe777cd6d88c7bca.jpg?hash=XPoYx42z4H)
![[Hearth.com] Best place to buy Double-Wall Insulated Chimney Pipe - Class A [Hearth.com] Best place to buy Double-Wall Insulated Chimney Pipe - Class A](https://www.hearth.com/talk/data/attachments/299/299266-3fd33abf6d2fde4d6c0424823b67d43e.jpg?hash=ij6GqjaRwI)
![[Hearth.com] Best place to buy Double-Wall Insulated Chimney Pipe - Class A [Hearth.com] Best place to buy Double-Wall Insulated Chimney Pipe - Class A](https://www.hearth.com/talk/data/attachments/299/299267-a88e2da6000d33f05d75364e16796c60.jpg?hash=t_6_BWYuul)
![[Hearth.com] Best place to buy Double-Wall Insulated Chimney Pipe - Class A [Hearth.com] Best place to buy Double-Wall Insulated Chimney Pipe - Class A](https://www.hearth.com/talk/data/attachments/299/299268-c1e84c770c3fbc8f75e46ff7eddc37bb.jpg?hash=GArk2muM1o)
I was just going off thisThat doesn't sound right. Someone may have their pricing list messed up or they are not the same outer metal. DuraTech is available with a galvalume outer jacket.
DuraPlus has always been their value line. Make sure that the length, diameter, etc. are identical. The fittings, like a Tee are where the difference really shows up.
View attachment 299238View attachment 299239View attachment 299240View attachment 299241
Dura plus is a far inferior product regardless of price. It has half the insulation so it looses much more heat. The cooling jacket can cause drafts. Wasps etc also love to make nests in the cooling jacket leading to an unsafe condition. It takes more space. And probably other reasons I am not thinking ofI was just going off this
BRAND FEATURES
See Parts List
- Most Recognized Brand in the US.
- Best Durability and Longevity.
- Best Warranty, Customer Service & Tech Support.
- Rated Best Product Based on Customer Reviews.
- Hide Features ▴
PIPE CONSTRUCTION
Double-wall pipeINSULATION TYPE
Thermal Tech blanket insulationMATERIAL TYPE
- .020” 430 stainless steel inner wall
- .016” 430 stainless steel outer wall
INSTALLATION
Professional Recommended* MOBILE HOME USE
YESADDITIONAL FEATURES
No locking bands or mechanical fasteners required- Limited Lifetime Warranty
Made in USA
Subtotal: $2603.70
** Would you like to include a chimney adapter?Select option...Single Wall Black - Slip ConnectorSingle Wall Black - Snap-LockSingle Wall Black - DuraBlack Chimney Adapter w/ TrimDouble Wall Black - DVL
BRAND FEATURES
See Parts List
- Best for mobile homes.
- Best Insulation.
- Best draft.
- Our recommendation for any mobile home installation.
- Hide Features ▴
PIPE CONSTRUCTION
Triple-wall pipeINSULATION TYPE
Ceramic blanket plus air space insulationMATERIAL TYPE
- .016″ 430 stainless steel outer wall
- .018″ aluminized steel intermediate liner
- .016″ 430 stainless steel inner liner
INSTALLATION
DIY* MOBILE HOME USE
YES- Limited Lifetime Warranty
Made in USA
Subtotal: $2984.92
so what brand would u go with?But quite honestly I wouldn't use either because of the 430 inner wall. I would want 304 or 316 inner
I use ventis or Jeremiah's. But Selkirk does make some nice pipe. A welded seam will keep weather out better than crimped seamso what brand would u go with?
BRAND FEATURES
We were unable to find the following parts for this brand:
- Premium grade stainless steel construction
- Smart choice lifetime warranty
- Mobile Home Installation Approved
- 1" Mineral Wool Fiber Insulation
- Hide Features ▴
PIPE CONSTRUCTION
Solid-packed insulationMATERIAL TYPE
- 304 grade stainless steel corrosion resistant inner liner
- 304 grade stainless steel corrosion resistant outer liner
INSTALLATION
Best for installations near ocean or salt water- Limited Lifetime Warranty
Made in Canada
You may consider purchasing another brand or continue adding available parts to your cart.
- Roof Flashing
See Parts List
Subtotal: $2032.42
** Would you like to include a chimney adapter?Select option...Single or Double Wall Adapter
BRAND FEATURES
- Mobile Home Installation Approved.
- Added Connection security with locking bands.
- The coolest under even the hottest conditions.
- Compatible with all Metalbestos chimney systems.
- Hide Features ▴
PIPE CONSTRUCTION
- 304 grade stainless steel inner liner
- 430 grade stainless steel outer liner
INSTALLATION
Made in Canada
- Roof Flashing
See Parts List
Subtotal: $2159.48
Hi Bholler, are you still using Jeremiahs and happy with it? Im considering using this chimney pipe. Also what stove pipe do you use? I dont think jeremiahs makes any or at least I cant find it online. Thank youI use ventis or Jeremiah's. But Selkirk does make some nice pipe. A welded seam will keep weather out better than crimped seam
Yes Jeremiahs is my favorite chimney so far. Not the easiest to install but the best finished productHi Bholler, are you still using Jeremiahs and happy with it? Im considering using this chimney pipe. Also what stove pipe do you use? I dont think jeremiahs makes any or at least I cant find it online. Thank you
