Came home tonight been gone since Thursday. 24 deg. outside, about 45 deg. in the house no heat on since I left. Turned on the heat pump and proceeded to put on a fire in the wood stove. Was unpacking in the bedroom and noticed it was getting smoky in the hallway! Dashed out to the front room where the stove is and smoke was pouring out the closed door, room was full of smoke!! The damper on the stove was wide open but the stove wasn't drafting for some reason, my first thought was the chimney must be plugged! I shoveled the contents of the stove newspaper, kindling and small splits into the ash pail and threw it out on the back lawn, took several trips! Opened windows and doors to let out the smoke then got the ladder and went up on the roof. Took of the chimney cap and shone a flashlight down the chimney, was clean as a whistle! Once the smoke had cleared somewhat I crumpled up a piece of newspaper and lit it in the stove, it didn't burn very well and smoke seemed to be coming into the room so I picked it up with my stove shovel and threw it out in the snow. In all this commotion with the house full of smoke the smoke detector didn't even go off
! I am sitting here now wondering what when wrong and what I should do next. I am definitely going to replace the smoke detector, it beeps when you push the test button but smoke doesn't set it off. Can anyone help me out, never had a problem like this before, have been burning in the stove on a regular basis. Am a little leery to try it again, what is wrong and what is the solution.
