- Jan 30, 2013
- 11
You were pretty clear, I was pretty fuzzy at 430 this morning
What's your chimney like? Is it masonry or insulated class A? If everything is already in place, installation is a snap. You could DIY, unless your insurance requires a professional install.
Is it worth an extra $1k? I guess it depends. The BK will burn for a long time with nice, even heat, and really shines in the spring and fall with the ability to burn clean at a reduced output. If it's not a big deal for you, go for the Buck. It's a solid stove.
We're all dry wood fanatics here, but it really is necessary for a satisfying burning experience. Get next year's supply now.
I think I'm out of my expertise as far as chimneys go. It's a metallic silver insulated pipe that goes stright up out of the stove, makes a 90 degree turn to the outside, then heads straight up through the porch roof.
I didn't really want to go with 8" because of the cost associated with it, although we were thinking that and a Buck 80 at one point. That's why we started looking at the Princess was for the cat and chimney size.
. There are a lot of stoves out there that will do a good job heating a house of that size. Given the choice between those two, get the Princess if you don't mind spending the extra coin. You won't be disappointed.
Cat stove wins...can't even imagine what it will do during shoulder season.
