Ok need help/advice from folks who know  wood stoves and have way more experience than I do!
We have a 2500 sq ft space. Its a 1961 built home so not the best insulation but its had a remodel so windows are efficient, walls are modern insulation just not much insulated ceiling or attic space as we have a lot of direct vaulted ceiling. Winter Climate here is typically lows in upper 30's, and highs of around upper 50's and lower 60's.
Our dealers in area are having a hard time getting stock so for now we're limited to BK Sirocco 30, Kuma Ashwood, or PE Summit. Unless we wait a month then we MAY be able to get an Iron Strike Grandview 300.
The BK Sirocco 30 intrigues me as we don't try to keep the house to hot (thermostat usually will sit around 65) so the low and slow seems doable. The long burn times would help my wife when I'm away for work. But it scares me that it lists sq ft range as 1000-2400 and I wonder if it can really do this space properly. It also seems to show a lower BTU than most so that concerns me too. Plus not sure if I should be afraid of a Cat stove as a chimney sweep said to avoid Cays as they will just require more maintenance/replacement
The Kuma seems to have high BTU, decent efficiency and is rated i think for 2800 sq ft. So to me it seems to maybe be better fit for large home. But also has shorter burn time but still decent efficiency.
The PE Summit seems to claim high BTU but has much lower efficiency and short burn time too from what I hear so I'm guessing this is just a more economical option to be considered but not sure if its true value or just lower cost.
Anyhow just not sure honestly about wood stoves so hard to read through burn times, efficiency, sq ft ranges etc and know that I'm comparing apples to apples so figured I'd see if anyone in here knew much about any of these models and could give insight as to good options for our home/climate.
PS Are blower motors worth it? We do have a large 72" ceiling fan fairly close to the stove too.
		![[Hearth.com] Blaze King Sirocco 30 vs Kuma Ashwood vs Pacific Energy Summit](/talk/data/attachments/267/267005-a0c9407c61e7eb85b4368a89f2be38bc.jpg?hash=5Pb52r2WG9)
			![[Hearth.com] Blaze King Sirocco 30 vs Kuma Ashwood vs Pacific Energy Summit](/talk/data/attachments/267/267007-6362714720e878e45512308ea7c52b4d.jpg?hash=vN6mVy47_D)
