Mine does pretty well with single-wall. But I guess I have pretty good draft. YMMV. Just sayin', don't necessarily buy into the expense and more-complicated installation of double-wall, just because BK specifies it (they'll admit not everyone needs it), if you can conveniently try single-wall first.
True.
Mine worked great with an older non cat BK, but had to upgrade & make a few changes for the new catalytic.
Cooler exhaust temps, chimney cooling in sub zero temps & real cold heavy air conspired to cause draft reversal & CO alarms when the weather got cold.
New double wall stove pipe, shorter horizontal, 2 45° replacing a 90°, tight joints, Now it works well.
Each system is different.
I was glad I was home when the reversal happened. Worked great for Oct & Nov, then it got cold.
So, if you try a less than the code or specified installation, make sure to have working CO alarms.
It may be impossible to test it in all conditions. If you loose draft you want to know right away.
One of those "risk assessment" things. CO in your home is bad.
When in doubt, have having your system inspected & tested by the pros, is prudent
Here, getting a draft started on a -20° day with a cold stove is a challenge.
Which reminds me, time for the thread "New batteries & testing of fire/CO alarms"
![[Hearth.com] Blaze King T-stat Questions [Hearth.com] Blaze King T-stat Questions](https://www.hearth.com/talk/data/attachments/74/74287-f753b0a26a439e064779759ad713b57e.jpg?hash=wrEFiAiaVQ)
