Blazeking or Pacific Energy - 1st time buyer
Fargo
84
North Dakota
Once again, I'm looking at purchasing a woodstove to install into my house. (I started looking a year ago but haven't done anything yet.) I'm really struggling between the benefits and drawbacks between the BK Ashford 30.2 and PE Alderlea T6. I have zero experience with woodstoves so everything I know has come from reading this forum. From reading this forum I have pretty much deduced that the Blazeking is the best cat stove and Pacific Energy is the best non-cat stove. So thats what brought me to these 2 options. My local dealers don't typically carry either stove, but I have found a dealer that can order either one for me. I don't have final quotes yet, but the dealer said the price difference between the 2 stoves is within a couple hundred dollars. That is before the current government rebate of $2000+/- (that I believe would only be available on the Ashford). So practically speaking the Blazeking is $2000 cheaper after the tax credit. (Assuming I meet all the requirements). But more important than price, I feel like I need to find the right stove for my needs.
The stove will be in a finished basement with a walk out patio door in the same room as the stove. The size of the house is 1700 sq ft 1 story house. So 1700 sq ft in the basement and 1700sq ft on the main level. So 3400 sq ft total. I'm hoping the heat will draft up a semi open stairwell to the upper level. If not I have a force air furnace I can use to circulate heat. Since I'm in a basement I expect my chimey stack will be around 22'-26'. (I haven't done the math to get exact estimates. I'll leave that to the installer). It will be a strait pipe through an upstairs closet. So mostly internal chimney up through the attic. I am a little bit on a side slope if that matters. But its a gentle slope and I'm not at the bottom of the hill
Since I have a pretty effecient electric force air furnace with a heatpump, I expect to only use the stove during the coldest 4 months. So I don't think I need the low and slow heat of the Blazeking. I expect once I fire it up, I will be able to run it at more moderate temps to supplement the furnace. Although I do hope to be able to get 9-10 hour burns over night so I can easily start the stove again in the morning.
What really draws me to the Blazeking is the thermostat. I see that as a huge saftey factor in allowing me to run the stove overnight and not worry about the stove running away from me while I sleep. The drawbacks I see, (apart from mild concerns about the Ashford smell issues) are the additional hassel, maintenance, and cost of cleaning and replacing the cat. And although, I wouldn't consider myself a 'prepper', I do take into consideration the longevity and reliability of the product, So I also, have some concerns about future availabiltity of a replacement cat if I ever needed something on short notice during an extended power outage. (We have had periods of being without power for a week in the past few years). Or if supply chains get all messed up again. So the cat free T6 just seems like it would be a longer lasting, more durable and reliable product to me. But then again, I might just keep a couple spare cats on hand to solve the problem. But its still sounds like more maintenance and complications than cat free.
The appeal of the Pacific Energy T6 is primarily the simple maintenance, and expected durability and reliability of a cat free stove. I also really like the ability to cook on the stove. This would be very helpful if we get another event where we are without power for a week. My concern with the T6 is I hear they breath very well and I am concerned it could run away from me at night. My other concern is also if I will be able to get a long enough burn over night for the stove to be running the secondary burn all night to be efficient and still have coals to start a new fire 9-10 hours later in the morning.
Since I am in a rural property in North Dakota, my primary wood source will be Boxelder trees that I have to constantly be clearing and cleaning up around my yard. So I might as well heat with them. However, since my wood is not great, and I expect I won't be very diligent at getting my wood seasoned property, that adds to the appeal of the T6. I understand cats do not handle unseasoned wood very well.
So, sorry for the long explanation. With all of that info. Which stove do you guys think will best meet my needs.
TLDR: I'm torn between the safety of the thermostat and the long over night burns on the BlazeKing Ashford 30.2 vs the simplicity, durability, and less maintenance of the cat free Pacific Energy Alderlea T6. The stove will be used for supplemental heating in the coldest 4 months of the year, along with emergency heat and cooking when the power goes out. As well as some time just enjoying the fire show for an evening. My wood will be boxelder and I am not sure I'll get the hang of proper seasoning.
Additional info; My basement is insulated, but not currently finished. But I'm considering the stove now to take advantage of the tax rebate. So getting the Ashford means additional work of disconnecting the stove to finish the basement then reconnecting again.
I can only speak from running the T6, but it is definitely a less complex stove with lower maintenance costs. The only runaways we have had, are when I have spaced out turning down the air. That is about 4 times in the past 16 yrs. The stove responded well once the air control was closed. A remote wireless thermometer system with an alarm cured that issue. If the cat stove is going to be only used on the colder days, then the burn times get closer.
That said, both are good stoves and will get the job done, assuming there is a good convection path and the basement is well insulated. Regardless of stove choice, the firewood must be properly seasoned to get good results from the stove. If the box elder was cut/split/stacked this year, it's likely not ready to burn. Note that the stove needs to be installed by 12/31/25 to get the credit.
Good idea to have an alarm. Does your T6 require much adjustment through out the day to keep it running at the correct temperature? Since the T6 doesn't have a thermostat, how often do you need to adjust the air control?
No, it's pretty predictable. Most of the adjustment is done in the first 30 minutes of operation. Once it's cruising it can go 10-12 hrs. on a full load in above freezing weather and about 8 hrs when I push it harder in sub-freezing temps. I might open up the air a little during the last hour to burn the coals down more. Our house is an old farm house with too much glazing so not the best for holding heat.
Reactions: Itslay90
This is not that untypical. A big Drolet, Osburn, Liberty, etc. will run about the same.
Reactions: Burnin Since 1991
So, if I am understanding things correctly, it seems whether I get a Blazeking or a PE, I'll be watching the unit for the first half hour or so and after that I should be able to turn it down and let it go.
I'm just watching videos now of the 2 stoves trying to get a feel for each unit. Both seem really nice with pros and cons. The PEs really have a nice fire show from what I've seen. But I do see a number of videos with issues of over fireing. So its still a concern, but it seems like there are solutions.
I have a couple of cat stoves. I need a backup stove since we have no backup heat except for a couple of oil-filled radiant heaters (small house.) I'm thinking of getting a secondary-burn stove and getting rid of a cat stove. I got an Alderlea T5 for my SIL several years back, and I'd go PE, except for that the stove needs to rear-vent into a masonry fireplace chimney.
I like the simple construction of the PEs, the low maintenance cost, the "floating firebox" etc, so in your shoes I'd go PE, without a doubt. Seems like a solid long-term investment to me.
I run my T5 more or less the same when it’s 35 or -20. I run it turned down. When it’s real cold it drafts harder. More air is pulled in. The fuel burns faster. I get more heat.
I also vary load size to give me more control over the heat output. I have a key damper on mine as a last form of draft/temp control.
Every stove operates differently. You’ll figure out how to run whichever stove you choose the best for your specific setup. No 2 loads are the same. Each load has a different amount of fuel in it, the fuel has a different moisture content, the wind changes, you end up turning the stove down faster/slower, the barometer is different… it’s a dance.
But if you run it the same each time, you start to rule out variables. You can make small changes and get the results you want without much effort or thought put in. This is key if you have to reload at 3am while half asleep and don’t want to burn your forearm on the door.
Question. Yesterday I was running my stove I let it roar for 20mins then I started to lower the air control in small increments, when I get to the last increment I close the air control fully and open it just bout lil at this stove about 1/8 open then the secondary kicks my flue temperature was 420 and stove top was 550.outside temperatures for 20 degrees.in then after about 2hours the fire dies out and my chimney smokes all my firewood is is 16-17 percent what can be the problem?
...I got an Alderlea T5 for my SIL several years back, and I'd go PE, except for that the stove needs to rear-vent into a masonry fireplace chimney.
I'm pretty sure the Alderlea can top vent. Or are you saying in your specific setup you need to rear-vent into the masonry chimney.
Right, I need to rear-vent into a fireplace. The lintel is only 28.75" so my stove choices are limited.
Burning wood is kind of an art form. There are pros and cons to any stove, and several variables that can lead to mixed results. A wood stove is not an automatic appliance, regardless of how its sold. The species and moisture content of the wood, how the stove is loaded, air control setting, outside temps, draft strength, etc. are all factors that go into how the stove burns. But the number one variable is the operator. Like my dad used to say, the most important nut in a car is the one behind the wheel. Note that some videos posted are of user errors.
This thread provide a sense of what a T6 is like to start up,
Reactions: Dix and Fargo
Blaze King have their install/maintenance instructions on their website, I’m assuming PE would also. Reading thru them would give you an idea of their respective maintenance requirements.
As a BK owner I’m impressed with their product. My only comparison in an older Regency R3 and an even older SBI stove.
No matter what stove you decide on it will train you depending upon the factors listed above.
If your burning primarily Box Elder go with the Blaze King. It will give you a more reliable overnight burn with softer woods.
That's an advantage of the thermostat, stringing those loads of lighter wood out evenly over a longer period.
That said, my SIL's T5 is still giving off good coal heat in the morning, even with loads of lesser woods like Red Maple or Black Cherry.
Her stove doesn't have the EBT, but that should control the burn rate to an extent as well I'd imagine.
Begreen's great thread on the T6 shows if the stove is loaded, cruise will be at least 600 degF. ...do you need that much temp/btu's? If not a cat stove that can be throttled back without using a smaller load might work better for you. I burn a Jotul F45 in MD, I do not need 600 STT, hence I must burn smaller loads to keep STT below 500. I hope to buy a cat stove next year and hope it's btu output/ can be controlled without using smaller loads.
It runs fine with a partial load at a lower temp. A half load will burn for 4-6 hrs. We usually cruise at around 450º stovettop in milder weather. However, like the OP, we have the heat pump for shoulder season heating so most of the time the stove is running with a 3/4 to full load these days. We've only had one fire so far due to a warmer than usual November, that was yesterday evening. Once the stove is warmed up, just throw a couple splits on the coals for even lower output.
I’d ask if the BK is able to be delivered in the next 6 weeks. Word is supply is tight.
Heatpump and tube stove is a great combination. I get the BK appeal. It requires more dedicated schedule to really run as intended than I have. If I’m cold I light a fire with as much wood as I think I need. I want more flame open and add some. If I’m busy I just let the heatpump run until I have time to light a fire. Yes you could probably run a T6 on a tight schedule too.
BKs are great for low and slow and constant heat. Once you get to a need a 3 load per day it’s a much more even playing field
Supply is indeed very, very tight. This is not a push for our company, but if the dealer does not currently have it in stock, it's likely you may not have sufficient time to get it installed.
BKVP
I was away from the computer yesterday. You guys left a lot of great replies. Not sure I can reply to all the input. But thank you everyone. I'll reply to a couple thoughts here.
.... A wood stove is not an automatic appliance, regardless of how its sold. The species and moisture content of the wood, how the stove is loaded, air control setting, outside temps, draft strength, etc. are all factors that go into how the stove burns.
Thats a good point to keep in mind. I tend to think of the Blazeking as an automatic appliance. But I'm probably setting myself up for failure if I think of it that way.
That thread you posted is great. I read your first post and it was very helpful. I look forward to reading the rest of the thread.
That is really the appeal of the Blazeking. It seems it allows for longer overnight burns and, I assume, less time tending to the air supply.
The thermostat is really the appeal of the Blazeking. Primarily because it more or less ensures a consistent overnight burn. But its nice to know the T5 and non-cat stoves can still have heat in the morning. But how much heat is still left? It sounds like just coals, so I assume the secondary burn is not happening.
So what happens to something like the T5 or T6 if it burns out overnight? If your just down to a bed of coals are you loosing ground? Will you get back drafts down the flue if your fire gets too cool overnight.
We burn softwood, Doug fir, almost exclusively.
I appreciate knowing the wood you use. I keep looking at BTU charts to see how it compares to my boxelder.
I don’t know if you ever burned Boxelder but it’s a far cry from your Western Doug Fir.
Most of the BTU charts I've seen show Boxelder around 18 and Doug fir above 20. So it does seem to be a better wood.
I do have some concerns about the availabity of the BK. One of the places I called said they were 4 weeks out. So if that's the case I might miss out on the rebate. Which was the primary reason I am looking to get something installed NOW.
Its interesting that you said the BK required a more dedicated schedule. I figured it was the opposite. I thought because the BK offered longer burn times it would be more flexible and not needing such a fixed scheduled to load it. But I think I understand what you are saying. Especially if your just lighting the fire when you feel cold.
From what I've seen it would appear that a cat stove like the BK needs to run a good half hour or so until you can close the flue and let the cat do its work. But until then, its pretty inefficient with the damper wide open. Where the T6 looks like within 10 minutes you could have a fire going and close the door and turn it down as it heats up. So less heat loss through the open flue. So maybe the BK is better for continuous use and the PE is better for short term operations.
The "30 minutes" is when you have a cold start. Just load it while the cat is active and interface duration may be 5 minutes.
BKVP
BKVP
This would be disappointing. As much as I've been back and forth between the 2 stoves. I was really leaning towards the BK, in part because its $2000 cheaper after the rebate. But missing the rebate may not be a bad thing. Since my basement is currently unfinished, putting it off another year would give me time to complete my basement before I installed the stove. Which would eliminate some headaches trying to work around the stove. So to some extend, forgoing the rebate just buys me time. But its expensive time :)
So that's part of the reason I'm trying to find the best stove for my needs and not just looking for the cheapest option. I see it as a long term investment.
Investment is a good way to think of it. You’ll be looking at either of these stoves for a long time. Buy the one you like best.
