Bolt snapped in Pellet Stove
md2002
374
United States
Looking for any recommendations or if anyone has had this issue. The bolt on my pellet stove which holds the bracket to hold my walls in place snapped off in the hole. I've tried drilling it out, melting it, hitting it with a hammer and nail set. I can't get the broken piece out. Any suggestions?
  • [Hearth.com] Bolt snapped in Pellet Stove
Drill a centring hole.
Heat the bolt red hot.
Fast cool (water )
Heat again
Using an easy out, turn the broken stud out
Old mechanics trick
Good Luck
Reactions: Ssyko and Washed-Up
sometimes that works not always. last resort drill out bolt with a bit just under the minor dia of the threads, re-tap at original size. broken bolts/screws = pia. another trick is to try and drill out with a left hand bit again just under minor diameter. Sometimes that works and may unscrew the portion that is left, similar to and ez out but of course the drill bit doesn't flare out bottom to top like ez outs ( which are anything but ez) and doesn" require trying to hammer it in yo get a bite ( which tends to bind things up even more)
Thanks for the ideas I'll give it a shot, I've never heard of an easy out. I did try drilling with a smaller bit but the drill would drill. it didn't make a dent in it but I may just need a better drill bit than what I have.
I've seen someone tack weld something to it, but in this case it's too small. Drill with a good bit, low speed, max pressure and some oil. Get a small easyout for sure.
Reactions: Ssyko
This is the kit I have
comes with centring guides, drills and non-flaring extractors
Not cheep
Not cheep
Nice Kit. I just spent 10 minutes looking for mine. I have a small one that I've had for 40 years. I guess I'll find it at some point.
Here is another example
Reactions: Ssyko
Drill that PITA bolt out, put a bigger (if needed) self tapper screw in its place and keep going. I've done that to numerous bolts like that bracket before, paint over it and touch up the interior so no one will notice the shiny color... my go to interior color was always Goldenfire brown by Stove Bright. Make sure the vacuum is running too to suck up some of the paint fumes... Good luck.
Reactions: Ssyko and johneh
What about a reverse drill bit? Between the drill bit and the reverse action you may get the screw to back out.
Never heard of that. What are they for?
Reverse twist drills are used mostly to remove broken bolts that are not tight in the threads
But they are difficult to grip. Example starter motor bolt when the head has broken off the
The bolt is loose but inset in the engine block. If you were to use a regular drill, it may turn
right into the inside of the engine, eg Chev 350,238,327,6 litre and so on
almost all drill bits work in a clockwise direction. So as you drill a struck screw if the screw wants to turn you will be tightening the screw.
A reverse drill bit works in a counter clockwise direction. As a you drill into a screw or bolt that is struck or broken the drill bit will be loosening the screw screw or bolt. To be clear when you use a reverse drill bit the drill itself needs to rotate in a counter clockwise direction.
Standard drills and screws/bolts are right hand thread, What are being called reverse are left hand screws and bits. most extractors are left hand twist or cutting flutes
grab a couple of good bits from the hardware store, if you know the size of the one broke off, bolt size not head size, and get the tap for the next size up and that bit needed to for that tap. Drill it out and tap the new larger hole and put a larger bolt in , pick up a bolt at the hardware store while you are there.
Reactions: johneh and Ssyko
Yep 👍
Reactions: Washed-Up
