Breckwell P2000FS problems, need wiring help
johnny59
9
pa
New to the forum. picked up a Breckwell P2000fs pellet stove (wh98-10361) cheap, but in good shape. someone did work on the stove and butched the wiring. the board has a label with CE-301 on the front and 281399 on the back. from what I understand is this is a 4-rpm board. I have found two different wiring diagrams for this stove. need the correct wiring diagram or where the wires from the control board go. the wires off the control board are black, white, 2 orange, blue, pink, yellow, red, two gray and two brown. I would like to make sure its wired correct before troubeshooting the problems with the stove.
nobody can help as its getting cold in the northeast!
black is hot white is return for board .both orange go to high temp switch.blue is for combustion blower.pink is for convection blower.yellow to auger motor.these are all 120 volt wires.grays go air vacuum switch 5 volt. browns go to proff of fire snap switch also 5 volt
