Installing a 27000. Looks like I will need an adapter to convert from the rectangular stove exhaust to 8" insulated round stove pipe which will go through the existing 10" chimney. Seen a few threads on this, but still would like clarification on a few things.
From what I have found so far, looks like I need to choose between:
1: a "boot" which is a square-ish adapter that covers more than the exhaust orifice. How does this bolt on?
2 a "stack", which is a rectangular adapter that fits pretty much exactly over the orifice and bolts on to existing points on the stove.
Firstly, please correct me if my nomenclature is incorrect and these are indeed the options. In choosing it seems that 2. would be optimal because it seems it bolts to purpose made points and also (guessing) the flue could be swept with all the soot going into the firebox. #1 would be used when clearance is limited.
Also, I haven't checked alignment with where the flue pipe will come down, but there will probably be and offset. How is the offset typically dealt with. Should I avoid using flexible flue - it looks like it would be harder to clean?
Any links to good value, high quality components would be appreciated.
Thanks
J
Thanks
J
