Can I damage my pellets by stacking them too high?
arcticcat1
53
Eastern Me.
With lower pellet prices this year I've begun to start hoarding for the 2011-2012 season and with limited space in my basement I'm having to stack them pretty high (12-15 high).Some of these may sit there till the end of next season&I don't want them to be sawdust by the time I get to burning them.
Since they double stack pallets at the manufacturers storage facilities I'd say no... I never had any problems and my dealer double stacks 'em.
BTU said:
The short answer to your questions is "No"....the longer version to the question is still "No".. See picture of pallets stacked 4 high right off of a MAJOR dealer's website located in CT.
Our standard pallet is stacked 13 bags high....so again, I don't see any damage to speak of stacking a little higher than you might otherwise
The picture answers my question with out a doubt & you will be happy to know that the pellets I'm hoarding are Okies.Thanks.
Because its the norm doesn't make it right. If you had a choice, would you want your pellets from the top or bottom? We have purchased 22 tons at work and I make sure I pick mine up before they get handled and stacked. They have to crumble the higher their stacked. Just my take
LG's are 15 row (1.5 ton) pallets.
The weight per square inch from a pallet of pellets on the bottom pellets is slightly less than one pound per square inch (on a 43" x 50" pallet of Cubex it is 0.9302 pounds per square inch for the one ton 10 row stack).
Your stacking won't cause any problems, just don't be rough when handling them.
I hand stacked 2 tons ibn a small area, after a week 30+ bags tipped over, thank god my car wasn't parked next them, it's a Focus which would of turned into a Festiva!!
handling would do more damage than stacking the pallets on top of each other
rough handling will break pellets
stacking them and leaving them alone
should have no affect
FWIW, I recently attended an open house at the NEWP Jaffrey location and they had plenty of pellets in their yard stacked 4 pallets high.
they usually put a piece of plywood/etc between each skid stack to spread the weight load as well, so keep tha tin mind.
Handling them too much does more damage than stacking them high.
I re-stack 14-16 high in my basement each year and the ones on the bottom
are fine when I finally get to them. First year I made the mistake of stacking
the bags all in the same direction and they fell over constantly. Now I stack
each row (3&2) like the mfr does, and they stay put.
if you do get crumbled pellets from stacking them too high I will dispose of them properly for you... ;-)
